Sign in to follow this
A 323i trailing arm bolts right into a stock 2002 subframe,
9 posts / 268 viewsLast Reply
I'll find out this weekend.
Yes they bolt right up but... You will have to either fabricate a spring perch or tabs for coilovers. I am running coilovers so I simply welded tabs and they work great.
URL: http://www.2002turbo.com
and here is a pic from my car. If you intend to use the original spring solution, there is some work do do. Some info in my homepage.
ie do they position the wheels in exactly the same spot as the 02
trailing arms?
Nick
(nt)
if you know what I mean.
What I'm interested in knowing is will the e21 trailing arm on an 02
subframe make the track wider or was the extra e21 width in the
subframe between the trailing arm mounts?
Nick
'02 and a 320, so I can measure between the inner pivots of both if needed........
They'll fit in an 02 subframe fine. Its about 5mm or so wider on the ends I believe (on each side)
Still have my 323i arms sitting on a shelf..waiting...waiting...
matt
