Sign in to follow this
LSD picture.
6 posts / 98 viewsLast Reply
Here are my 2 lsd side by side. I figured something with my new acquisition.
This one is my "old" one, a 3.90:1 with 25% lock ratio as original (now 3.64 and 75%+noisy). There is 6 bolts that hold the side bearings and is the one that is hard to increase the % factor. Note the thin tabs on its side, where is sits on the subframe. You can see the 6 bolts. I presume this is the 79-83 model found on 320.
This one is my new acquisition. It have 4 bolts that holds the side bearings. The tabs are beefier. Its inards permits the addition of 2 more clutches to go for 40% slip, wich is what there is inside actualy (cool) it is marked 40-11 wich is a 3.363:1.
The casing is identical to a 02 diff, no one could tell the difference. I believe these could have been found into 02 as well. Note the 4 bolts on the side and the beefy tabs...
And a side by side picture...
So if you shop for a LSD, be sure to what you get/want !!!
Pat Allen
(nt)
yeah, id like to find a lower gearing just for that, i got power to prepel it !!
Pat Allen
(nt)
(nt)
