Horn/washer/wiper electrical issue
My horn stopped working (more accurately,
stopped receiving messages from the steering
wheel, the horn unit still works) It was intermittent,
then gone. Simultaneously, the windshield
washer function failed. Not only the pump-the
wipers stopped coming on when you pull back on
the stalk.
I've replaced the stalk (worked a few times, then no
more), the relay and the fuses. I took the fuse box
off looked for loose connections. I tightened the
ground wires, I think I got the right ones. Any
Ideas?
TIA
If the fuses are good, don't think the two problems are connected. The horn contact is set into the steering wheel--a little copper thing on a spring like the brush on a DC electric motor. Pull the steering wheel, check the contact brush, and the brass ring that's set into the steering column. If the horn blows when you ground the brass ring to the steel steering column (use a screwdriver or pair of needlenose pliers) the horn and its wiring is OK. Then make sure there's contact between the horn pushes in the steering wheel and the contact button/brush. If not, it's a wiring problem inside the steering wheel. The horn pushes come off with screws on the back side of the wheel.
As for the washer--is the pump OK? They do fail on a pretty regular basis. If the fuse/fuseholder was bad, none of the wiper options would work. If the wipers operate the requisite four or five strokes when you pull the wiper switch, the relay's OK. If the pump is good, then the problem's gotta be in the pump wiring. If you have an early car, it's possible to hook up the pump wires backwards, so it sucks (so to speak) rather than pushing water out the nozzles.
Check this all out, and post what you've found.
Good luck
Mike
I've done the horn contact test...intermittent results,
But...when it does work, so does the wiper/washer
function! I was so excited (didn't take much)when I
found that the horn connected to the wiper stalk.
Replacing that only last for a few honks and wipes
though. The regular wipers work all the time.
The washer pump, like the horn itself works fine. I
just can't seem to communicate with them.
I'm hoping it isn't "weird".
car? Wiring is different on most years. If not, drop me an e-mail next week (I'm on vacation--just can't stay away from the board) with the year of your car and I'll look it up. The horn push on a 2002 is a grounding setup, so the horn wire in the steering column is a ground, not a hot lead (if my memory serves me). Sounds like perhaps there's a hot lead mixed up with a ground and that's what's causing the problem. I don't think the wiper hot lead feeds off the horn lead or vice-versa. You said you replaced the wash/wipe stalk...are the wires at the connector exactly the same on the old and new ones?
That's all I can think of right now without any of my references to consult, but it is a weird one...
Good luck and good hunting
Mike
Mmmm. Vacation. I could work on my car. What
am I thinking. I'm on perm vacation after next week.
sigh.
Anyway. I do have the wiring diagrams... just don't
want to look, I'm not much for electrical
troubleshooting. But your right, it probably has the
answer. Yes, the stalks were the same (and I
threw the old one away when the new one worked,
duh) And I may have mentioned, it worked
consistently then for a day or two. Then nada.
Thanks again
Melinda
