funny dashboard Q.???
NE 1 know why my turn indicator light would suddenly show very dimmly all the time? This occurred at the same time that the high beam indicator quit working. It's a 76 if that makes a difference, and the turn signals and high beams all still work fine. I know there can be funny electrical things on these cars, so thought this might be common. Thanks for any help.
Don
URL: http://www.my2002tii.com
there are a couple of grounding points under/behind the dash... also the bulb contact itself might be getting corrody on you a little bit. There is a total write up on refreshing the instrument cluster over at www.my20002tii.com... HTH!!
-Rob
thanks Rob, it's gone away for now so you are probably right about the corrosion or ground situation. Don
