Help with battery tray problem
2iuftg
I purchased a replacement battery tray from walloth and nesch that came with a BMW sticker showing part number 41 11 1831 275.
The original trays has a nut welded onto the bottom to accept the retaining rod for the battery. The new one appears to use a body nut.
Is there a factory body nut with a b6 nut on it as opposed to the ones that accept the coarse threaded screws ie for the radiator?
I can probably TIG weld a nut to a modified raditor body nut but if there is a factory piece I would rather have that.
