Easiest way to remove broken beltline molding clips?(nt)
IF YOU MEAN THE PLASTIC ONES , YOU CAN USE A SMALL
PUNCH TO TAP THE LOCKING PIN OUT FROM THE INSIDE .
A PIECE OF MASKING TAPE ON THE OUTSIDE CAN KEEP THE PIN
FROM GETTING LOST .
IF YOU CAN'T GET ACCESS TO THE INSIDE THEN REVERSE
THE PROCESS AND PUNCH IT THROUGH FROM THE OUTSIDE .
ONCE THE PINS ARE OUT IT IS EASY TO PULL THE REST OF
THE CLIP OUT WITH PLIERS AND A GENTLE TWISTING MOTION .
