Which carb set up would work best?
I have a 1976 modified engine, it presently has a
32/36 Weber carb. After some research in the
archives, I am thinking a 38/38 or a dual
sidedraught setup. I am not racing the car, it's a
street car / my toy.
I think the 32/36 would be the best on gas, but I
might get better overall performance from another
setup. I don't know what scenario to follow and
would welcome some feedback. If you
recommend anything other than a 32/36, what
should I go with as Weber's are not available at
present?
The engine has been bored to 40 over; has been
ported and polished; flywheel has been lightened;
292 Schrick Cam; JE forged pistons; bav autosport
headers, ansa free flow exhaust and muffler. The
engine had some other mods done that escapes
me right now. It was done by a professional race
shop, lead mechanic was knowledgeable of 02's.
I think compression was 10.1 or 10.5. He stated if
I went any higher I would have to mix gas.
Thanks in advance.
As a minimum a 40/40. It is very strange that they ONLY fitted with a 32/36, did they ran out of money???. Not to be skeptical, but it may be worth opening the valve cover and verify cam.
the engine later. I have not fired it up yet. I actually
learned how to tell the difference in Carbs from
folks on this board.
The carb is not connected to the engine; I looked at
it again before posting earlier hoping that it was at
least a 38/38 - not!
Exactly what set up would you recommend? How
would a conversion go on a 76 engine
(desmogging)? I would need to change the
manifold and plug lines? Help???
Thanks in advance.
Roger
that u only use 2? pieces from. makes it a cheap non progressive carb, lottsa fuel almost too much for 7k feet up here. fouled 3 sets of plugs.
Someone made one outta a bic pen but still waiting on their pics! 8)
URL: http://dubois2002.com
I would first check the google search in the main menu, find out who has a similar set up engine wise, and find out about the intake from them. I would definetely go side drafts, but that is only one opinion. There are a lot of people on the board running side drafts. I would repost with sidedrafts on the title post. If you live in California there are smog issues to think about.
