Early BMW 2002 or 1600 Master cylinder
Hello, I need an early Master Cylinder or one that works for a
69 BMW 2002. It has the Double resevior, and if you have a
complete system in working condition including the brake
booster I'd be interested too.
Thanks
unit works well, with one minor adaptation - the '02 brake fluid reservoir "nipples" are smaller than the 320's, so the m/c reservior grommets are different sizes. I wound up using both (320 grommet in the m/c, then the '02 grommet inside the 320 one with the reservoir "nipples" stuck through the '02 grommets) - it was a bit of a pain to get everything together, but it's been assembled for 2.5 years now with no leaks.
