Rear disk brakes
Works fine, but make sure he supplies you with the calipers that can take the '02 e-brake cable. Some of the VW calipersaccept the e-brake cable more easily than others.
Ian
'76 M2
Basically, VW Rabbit front solid rotors and Golf/Jetta rear calipers, turned hubs to fit the inside diameter of rotors and an adapting bracket.
What is nice is the parking brake being integral to the caliper, but what is not as nice is that the caliper ends up being horizontal. Which means that you need to remove it everytime you bleed it. There is no other position around a 2002 trailing arm.
