Pertronix/ Ignition Help
I have told you before about how my pertronix refuses to work. I have come to the conclusion that either it is a faulty chip, or I am not hooking up wires correctly. I have included some pics of my current setup. There is that bok directly in front of the coil. Should some wires be routed to that? I will also be using a Red Coil when I have it figured out.
Thanks again
Are you using some kinda pull down on the throttles? I'm confused. You've got the cable inlet towards the FRONT of the car. Not right if you're going cable throttle.
BigDog
'76 2002
Not supposed to be. I think you just take the red wire to the pos on the coil and the black to the neg side. Unless you are running it through a ballast resistor. Try it straight to the coil first if you are.
