What glass to rubber adhesive to use?
I'm gluing the triangular window into the "L"
shaped frame. I'm using 3M weatherstrip adhesive
for the metal frame to the rubber insert, but need
something for the rubber to the glass. Any ideas?
TIA,
Rob
Hope things are good for you! I'm hoping to make it back that way some time soon. Drop a line
privy13@hotmail.com
URL: http://pageproducer.arczip.com/mdyjc/BMW2002page1.html
I didn't think through my last post well enough. No adhesives are needed for vent glass installation. It should be a very tight fit. Use a rubber hammer with a soft wood plank or a plastic cutting board as anvil. Visualize the center of glass radius and center of chrome radius and hammer them together. After start there is no adjustment. Misaligned start? Remove and start over.
Anyone who works on car bodies needs to know about certain wurth products. After you use rubber adh. you'll never use another brand. The best way to fill visible seams such as external rear body panel, and fender to front panel, both inner and outer, is with their squeeze tube, needle nose seam sealer. I have forgotten the name.
