damn pinging
ok all.
took out the 02 yesterday for the first time in months. thought I'd let it out a bit since I hardly run the gal.
My car has always "pinged" under hard acceleration since the restoration several years ago.
Problem though is that everything should be set.
new engine - no worn components
co2 mixture on pump is good
timing is good
plugs are good
no fluid leaking into brake booster
no intake issues
no carbon/buildup (remember, new engine)
warm up regulator is good
cold start valve is good
I see no reason why it pings but it does. It does it between 2k-3k rpms under heavy acceleration. It doesn't do it during normal driving conditions. It starts up fine in both cold and warm and has a perfect idle.
what am I missing here?! it's so annoying to have a car that you've gone over everything with do something like this.
I have a 2 liter motor that did that with 9.0 pistons, 275 degree cam - lash caps -A very mild tune I have a suspicion that it may be the cam.
Slavs
Are you in CA where 91 is premium or at elevation where 87 is all that's available? 87/89 seems a bit low for a tii near sea level.
My car pings like mad on 91 octane, runs fine on 93.
I have 10:1 pistons and a 300degree cam. PO (and engine builder) calculated 9.8:1 CR but was using a +.3 head gasket at the time.
If you run low RPM and are trying to boot it, then chances are it is going to ping. Try by backing ignition a bit, but run higher RPM.
it does it between 2k-3k rpms under heavy acceleration. I'm not "under-geared" at the time either.
My tank was dropped and cleaned when I did the restore 3 years ago and have tried various octane levels for multiple gas tank fills.
It does not go away with higher octane.
See my frustration? This will be the year I nip this in the bud!
Great input so far. Much appreciated. Thanks.
I would check the valve timing. I'm just thinking if a valve or two are too tight then maybe they could tap the piston. No? I'm just guessing. Maybe the timing was never set right to begin with.
