Anyone have ti airbox dimensions / pictures?
I am designing my own airbox for my Dellorto carbs to use with a non-tii brake booster. I will be doing a comparative CFD analysis with a ti airbox but I need some dimensions. I need the diameter and overall length and also the length of the air inlets and the diameter of the open end of those inlets. I also need a photo of the end cap and filter removed so I can see what it looks like under the filter. I have never seen one so I can only guess at what it looks like.
Or even better yet, anyone in the Portland, OR region with a ti? In my earlier post about mounting the airbox, there was a reply with a complete ti setup for sale, but I can't remember if that was near Portland.
Any help would be much appreciated, thanks.
There are two styles of "ti" airbox. One is for the 4 door Neu Klasse "ti" cars, and the other is for the 02 "ti" cars. The 02 style is shorter. It also has an indenteation on the underside, designed to clear the "ti" brake booster, but not the standard booster. Furthermore the 4 carb intakes where the baffles mont come out at a shallower angle on the 02 style while they are welded at 90 degrees on the 4 door. The plane on which these sit is also not parallel to the airbox plane on the 02 style box.
The filter covers on the 02 style both sith so that intake is on the higher side near hood level, but on the 4 door one is high while other is low.
I have one, but I don't want to sell it.
I'm sure it will be cheaper to buy one than making it. They are out there and should never be more than a $100. The 02 style fits better since it is designed for the 02.
Slavs
