Brake & Master Cylinder Issues-Fade
Hello, I'm having brake problems that seem to be
getting worse. When I apply the brakes, they seem
to work fine at first, but when I hold them down,
they fade almost to the floor causing brake failure.
Is that a master cylinder vacuum issue? I looked
at the hose and it looked OK...I bled them a few
days ago and they seem to be fine, but when I hold
down the pedal, fade to the point of failure....I might
get a different working system and recondition it on
the workbench. I'm thinking new stainless lines
would help the system work better. If anyone
knows an easy fix to this problem, I'd appreciate it...
Does it use fluid? If so, definitely pull the master off of the booster, and look inside for fluid. You are not experiencing a vacuum issue. Loss of vacuum wouldn't cause the pedal to go to the floor, it would cause a hard pedal. You are experiencing some sort of loss (or limit) of fluid pressure. Most likely culprit is the MC; it probably can't take the pressure. If the leak were in the wheel(s), it would have to be in at least places...because the 2002 has a dual-circuit, and you would probably have pressure in at least one of them, thus keeping your pedal off the floor.
Mike
How many posts in the last week have we seen on spongy brakes, brakes that push to the floor sloowly...
It's been discussed, either you've still got air in the system (aka you didn't know how to bleed correctly), or your MC is failing loosing fluid into the booster, or you're leaking someplace.
Arrrrrrrrgh, sorry for the frustration, but that's the 3 things you're likely looking at.
BigDog
'76 2002 Big Brakes
Fluid goes past the piston so the pedal can go to the floor, the fluid doesn't leak out anyplace, just internally. No puddles, no fluid in the booster. Usually it holds if you push hard, then if you push softly it slowly oozes down to the floor. Replace the master cylinder, you're good to go.
