Gravel guard frt end original ?
My bodyman says gravel guard on front valence was original on my 72. True ? If true, exactly what area was covered. If not true, what area would you guys recommend I get covered if I decide to go that way ?
Now the rockers. If I get them covered with gravel guard, will the clips and moulding fit correctly ?
Finally the rear end (I have the long bumper). Should I spray rear valence below bumper c/w lower part of rear fenders ?
Thanks
under the paint and over the primer, the factory used it up to the crease in the nose panel that's approximately alighned with the bumper brackets' lower edge on roundies. It's a fairly sharp cutoff (no overspray above that line)so it must have been masked, and also includes a little triangle of front fender ahead of the wheel opening.
Not sure where the cutoff line is for squarelights, but I suspect it's about the same as roundies...
Cheers
Mike
