Trans Tunnel Mod
URL: http://sports-car-restoration.com/gallery/
Here is a before pic of the factory transmission tunnel:
Here is the "after" pic of the custom tunnel I made: Removable and bigger, 20-ga steel, ribbed, shrunk, stretched, beaten and wheeled into this shape:
Transmission rear pickup will be mounted on a removable X-brace connecting the framerails.
The gaspedal still fits fine, about as tight to the tunnel as my e28, a little tighter than the 02. I will probably modify the brake and gas to move them to the left just a little.
From the top:
Another:
Not done yet, but its getting there, damn customer's cars and wife keep monopolizing all my time.
Matt McGinn
SportsCar Restroration
Very nice! I am fabricating a new transmission mount for my M2, as I need to lower my tranny slightly. How are you going to make the x-brace tranny mount for your car?
Ian
'76 M2 (gradually being reassembled)
Clutch jobs were pretty easy....take out seats, take off tunnel, remove tranny from top. But when you were done, it was still a Triumph. I traded that car on my first 2002, in 1978.
Thanks for the compliment! The brace will be made from 1" DOM tubing most likely and will form an X that intersects under the transmission mount. I am going to have to weld nuts and plates into the framerails to secure it.
Matt
The x-brace sounds much stouter than what I was planning, and might even stiffen up the chassis. Please post some pics when you do it, as I could use some inspiration, and am not averse to welding tabs to the frame rails to mount the bracket.
Ian
