Brake Booster to Manifold Plumbing SS
'02 amigos,
Here's the partnumber brakedown on the brake booster hose replacement plumbing with braided stainless lines.
(1) 3/8npt to AN8 fitting p/n AER-FBM2007 (summit)
(3) AN8 Hose Clamps p/n EAR-900108erl (summit)
(1) 90deg AN8 Hose End p/n EAR-809008erl (summit)
(1) AN8 Hose p/n AER-FCA0806 (summit)
The manifolds I have for my DCOE's have a 3/8npt hole in them for the vacuum to the brake booster. I used the adapter above plus the 90deg fittting to accomplish this. It's a little hard to see under the strut brace.
I also had to sand down the barbs on the brake booster check valve for the AN8 hose to fit over the ends.
I also did use a uni-bit to slightly hog out the hose clamp that is mounted on the brake booster to get it to fit.
All in all a pretty simple installation, just a little fitting necessary, and the hose clamps are easy to deal with compared to the official hose ends.
Here's that photo, again...
BigDog
'76 2002 Weber DCOEs
