Output shaft lock-ring orientation?
Go to solution Solved by Son of Marty,
  • Solution
They are still available for 2 bucks or so, 23211490120 at your favorite 02 parts supplier.
George S Patton
It's a use- once thing.
The second time, it just falls out again.
I've tried reusing them, and it never works.
The nut crushes the lock ring, and then a relief in the nut holds the ring
in place by compression.  Once that compression is released, like the magic
smoke, it just doesn't seem to want to rejoin the party.
  • Haha 1
Well if one is able to lure it out without it noticing what’s going on then one might be able to convince it to play along.
reuser
I notice the output flange has a small groove. (marked in yellow).  The original lock-ring must have required a deformation, that fit into this groove, to hold it in place.
Once installed, I will use a small drift to notch old lock-ring, and see if that works to affix it in place.
