lame group buy: adjustable sway bar brackets
I have designed "U" shaped brackets to attach the heim joints from my adjustable Alpina sway bar to the rear trailing arm and front control arm. The brackets bolt to the control arm or trailing arm and the heim joint bolts to the bracket. On emachineshop.com, the brackets are pricey, about $8 each if I order 24. I only need four. Anyone intersted in some?
