Race engine questions
I think the rocker locks are mainly for high reving engines or engines that will be run at high RPM's for long periods of time.
I might be wrong but this is what I've hear.
Leif
Lee, I run both. I'm not sure about the keepers but the lock are a big yes. You can buy them directly from Rutland
and save big time......
at high rpm's the springs that position the rockers can start to slide
around causing the eccentric to move off the valve. i did mine for
insurance and less clutter in the head. it's not a race motor but autox
and driving schools.
Ti retainers are worthwhile for an engine that sees high rpm use.
Ti will let you run lighter springs & result in less cam/rocker wear, and have fewer broken rocker arms.
The heavier steel retainer requires more spring force to move the extra mass.
Too bad there's not a cheap alternative to the heavy valves the M10 requires. Going to a 7 mm stem & guides would be worth even more weight savings, but the costs are far greater
The current trend is to use the "beehive" valve springs, which feature reduced diameter at the top coils. This allows even less mass at the end that travels the most, thru the smaller top coils + the smaller diameter retainer required.
At the Detroit Auto Show last month, I saw a Japanese automaker's engine that had this technology in production already. Great idea, why did it take so long to rethink the traditional valve spring design?
Same old basic parts, just a better design that's affordable for many applications.
They seem to offer metric and SAE sizes. The rocker shaft measures 15.5mm, my guess is that I should go with a 16mm and hope there is enough tolerance to be tight around the rocker shaft.
I may be wrong, but I was thinking the shafts were 14.5 mm and the SP-9-A collar (0.5625") could get reamed to size (14.5 mm is near 0.570")
If the shafts are 15.5 mm, then I'd find the next smaller size collar bore & use a reamer to finish size.
It ranges from $3.80 to $9.00
I guess that the regular black plated steel will do at $3.80. Bob uses aluminum ones, but I am reluctant when it comes to torque a small bolt in aluminum...
