Recommended motor oil
12 minutes ago, David Layton said:
Do not use synthetics, these are too thin.
I wasn't aware that synthetics used a different viscosity scale than conventual motor oil.
George S Patton
Marty,
Greg over at Bimmers R Us, whose experience with 02's goes back to the 80's, had helped me with the Kugelfisher installation and setting advised to stay away from synthetics as they were too thin.
AFAIK 20w-50 synthetic is the same viscosity as 20w-50 conventional oil (or a 20w-50 "blend" for that matter).  Viscosity is set by SAE standards, for an oil to have a specified rating, it must meet the SAE criteria.  Of course every oil company has its own additive package, the contents of which may make that brand more desirable for our cars.  And flow rates may differ slightly due to synthetic being more "slippery." But to say a synthetic 20W-50 oil is "thinner" than a conventional 20W-50 flies in the face of those SAE standards.  At least that's what I've been reading for as long as synthetics have been around.
PS--unless you're driving in very cold conditions, the preferred oil weight for M10s seem to be 20W-50.  Your choice of brands...
Some education on why synthetic oil is better than dino.  Suggest watching episode 3 on laboratory testing also.
LOL....it has been a while since there was a "what is the best oil" thread.
and the answer is, like every other time this comes up, there isn't one.  everyone has anecdotal experiences which point to the one they use....and they are all different.
the manual calls for specific grades and viscosities for different usages.    use that.   does not matter dino or synth.  or what brand.   just change it regularly and it will all be fine.
2xM3
28 minutes ago, tech71 said:
Yeah, what kind of “additives” they puttin in there?
You should ask that of any supplier if you are concerned about Amsoil.  You won't get an answer from anyone.
I like to buy this kit from FCP, used it in my E30 and my 2002 and have gotten good Zinc tests from Blackstone Labs. Comes with everything you need and I like the Liqui Moly product, it has never let me down!
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
