Diagnostic Port replacement?
Go to solution Solved by Stevenola,
Has anyone found a replacement for the diagnostic port socket in our '02s?  Mine has lost one of the 'ears' that hold it in place, and when I plug in my diagnostic tool, it doesn't always make a good connection unless I hold the socket while plugging in the tool's pins...even then, moving the tool around sometimes 'unplugs' the pins from the socket.
I've found similar Molex connectors, but not with the 2 tabs on either side.
S/N 2579886
Posted (edited)
12 hours ago, Stevenola said:
Thanks Steve...I'd searched for an hour before posting, and after posting searched some more and finally found this...
https://www.te.com/usa-en/product-1-480274-0.html  It looks the same as the 9-pin from Mouser.  Wish I'd seen the Mouser one first, as I live in the same town as them :)
Now I've got to look into pin removers to swap the bodies without having to cut wires and re-wire...
Edited by Steve76063
Add comment on pin removers
S/N 2579886
