High engine temperature
DrA76
Some years ago when my '69 was my winter daily driver (I know...bad, bad me, but I had no choice!) I noticed that for the first 4-5 miles on the freeway my temp gauge would climb up to about 2 o'clock, even with the heater going full blast (in the 20s-30s outside).  Then all of a sudden the gauge would drop to 4 o'clock, then gradually come back up to its normal 3 o'clock about the time I reached work.
After watching that phenomenon for a week or two, I pulled off to the side of the road while the gauge was reading high, and felt the hoses around the thermostat.  Sure enough, the 'stat wasn't opening until it really got hot, then it went from fully closed to fully open all at once--instead of gradually. I swapped out the thermostat and all was back to normal.
So if you've ruled out more common problems like a loose alternator/water pump belt, poorly grounding temp gauge sensor (it grounds through the threads so make sure they're clean), or a vacuum leak, you might check the hoses around the thermostat to see if it's opening properly.
PS--if the gauge itself is flickering or jumping--and especially if the gas gauge is doing it too, then you have a faulty ground at the gauge end.  Lots of posts on the FAQ on how to fix that.
My recent experience was a crudded-up radiator.  I took it to the local shop, he opened it up, rodded out the core, cleaned the tanks, then reassembled.  Cooling returned to normal.
     The radiator guy said it had more-than-plenty junk in the lower tank and the core.
I also installed a new thermostat, just because it was so easy to accomplish.  No reason not to.
Cheers,
Carl
Also check your timing.
Not enough advance when fully warmed up will cause engine to run hot. The later cars are especially sensitive to this if fitted with the dual pod distributor (vac advance and retard). The black electro valve allows advance only when the coolant temperature is cold. When car gets warm, the vac retard kicks in. If vac lines are not installed correctly and/or static timing is wrong … your timing can be too retarded = hot!
Been there….done that. 🤓
John
4 hours ago, DrA76 said:
I flush the radiator. Checked all grounds.
While driving gauge at 3 o'clock
In traffic 2 .
That's not completely abnormal.  When I'm in traffic, my gauge reads about 2:30--and that's with a 3 row core radiator, an 80 degree thermostat and an A/C condenser in front of the radiator.
So depending on the air temperature and which thermostat you have, and presuming your gauge is reading accurately, you're not too far off.  Since you have a '76, there should be a shroud around the fan to assist air flow, as those cars are burdened with a thermal reactor exhaust manifold that generates a lot of extra heat, putting a strain on an already marginal (for the US) cooling system.  If you have A/C, even more.
If you're not in CA--or another mis-benighted state that visually inspects emission controls, pitch that manifold into the neighbor's pool and install a "regular" exhaust manifold.  Your engine will run cooler, and the extra weight of the thermal reactor manifold won't put additional strain on the exhaust manifold studs, which weren't designed for that extra weight.
11 hours ago, John76 said:
82 degrees at 6:45 AM ?
Don't think @DrA76 is in CA.
We are having record rain and cold (north and south).
My idea that CA (at least the southern part) is always warm has just been shattered (not really, I found out first hand about LA's "June Glooms.")
But I still bet it's warmer in CA than here in OH...
