Door/Window Components Rehab and Two Questions
2002#3
Go to solution Solved by zambo,
I am rehabbing my second set of door innards.  This particular set of innards has not been touched in 53 years.  I am throughly enjoying removing/chipping off the dried, hard, recalcitrant grease in the guides and wheels, I had forgotten how much fun and enjoyment removing these components can be, and I do sooooo very much look forward to installing them as they simply, easily, gently, and effortlessly slip back into place within the door.  I hope the inner components within the other door are in worse shape so I can have even more fun.
The outer "chrome" window/door trim strip with the rubber squeegee* which rubs against the window and diverts most of the rain down the outer door...
Question 1:  Has anyone found a way to repair the Replaced only the rubber?  How?  Source of rubber?
Question 2:  Any FAQers have these in good order and for sale?
These trim pieces (left, 51211836291; right, -292) are available new from a few commercial sources.  However, paying $110 to $165 each is not my first choice.
Thanks,
Larry
Edited by 2002#3
  • Haha 1
  • Solution
That rubber strip is an easy slide in replacement - Walloth and Nesch for instance stocks it as am sure U.S. specialist sellers would. Its actually really inexpensive - a few bucks as I recall. The cloth covered metal section if its rusted out is also available separately.
The aluminium section - the expensive bit - can be refurbed ... if the anodising has gone off you can strip it and polish up the raw aluminium with a specific aluminium polish. Hope that helps.
  • 2002#3 changed the title to Door/Window Components Rehab and Two Questions
