Oh No! But fear not...
Polymerjohn
We can build her back...Stronger, Better, Faster.
This floor picture isn't the worst news I got today.  The frame rail is bent and cracked down by the pedal box.  Every problem I find is just an opportunity to make it stronger. I think she was moderately "tapped" in the front driver's corner.
John in OK
  • Sad 1
My guess is that the floor rust by the pedal box is the result of a long-term leaking clutch master cylinder.  It'll eventually fill the pedal box--it'll hold over a pint--(rusting it out too) if you keep adding fluid without checking where it's going.
And the frame rail rust probably began from a leaking brake master cylinder.  It'll drip and run down inside that driver's side frame rail, eventually rusting it from the inside out.  I'll bet the crunch is from a jack being used on the already weakened frame rail.
I learned both of the above lessons when they happened to my '69.  Both spots were repaired many years ago--replacement pedal bucket and replacement last two feet of the frame rail.
Is it possible to drop the subframe about an inch or two to make repairs easier?  I’m sure the driver’s frame rail needs completely replaced but I would like to strongly “patch” this and do the whole frame rail when I drop the subframe/engine/trans.  My metal skills are enough to do a temporary sound patch job, and handle the full replacement later.
If it was me I think I would do the repair once and do it right!
I have a feeling you're going to find more rust and other things that need attention.
I would suggest dropping the whole engine transmission and subframe as one unit. It can be done with a motorcycle/ATV jack.
Some more work to clean up things for welding (that tar sh!+ sucks), then I can start the cardboard pattern fun.  I'm gonna go further left to find good metal.  I'm pretty sure the fuel return line runs down that area so, I will be sure to protect it.  I also realized that 16 gauge steel is likely too thick.  I would be ok with +0.005" over gauge, but not 0.015" over.  I am going to reinforce the ring around the pedal box mount on the inside.
Looks good so far, if that’s the extent of  the damage there you are lucky.
The frame rail will be more of a pain, you could probably box in that area IF it’s not rusty on the inside,  if so it may not be solid enough to weld.
You can lower the subframe/engine  a bit but still have to separate the  steering coupler, trans mount, coolant hoses , clutch  MC  to slave  cyl as well as struts top or bottom.
Not all that much more( exhaust at down pipe, driveshaft coupler bolts, a few wires) and you could lower the whole shebang onto a furniture dolly and roll it out of your way.
Edited by tech71
  • Like 3
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
Strong > pretty any day!
No one sees down there and it looks stout. Nice work.
Jason
1973 2002tii (2764167), Baikal, sunroof, A/C, 5spd OD, 3.91 LSD, etc. Rebuild blog here!
--> Blog: Repro tii cold start relay;   --> If you need an Alpina A4 tuning manual, PM me!
