Big gas leak on Thanksgiving morning, very thankful
there's a big long thread on this not so far back.
TLDS-
There's no 'right' way, but lots of options.
use 5/16" hardline for most of it.
You can still buy the OEM flexible plastic fuel line that's self-sealing if exposed to excessive heat (the thread Toby is referring to).  It'll work just fine and is a lot easier to route than metal line.  And it won't be near 50 years old, either, like yours was.
As conscientious as BMW was (and presumably still is, in these litigious days) they wouldn't have routed plastic fuel line through the passenger compartment if it was even slightly dangerous.  That yours  broke right by the firewall indicates that the end that exposure to both light and engine compartment heat probably degraded the plastic--and/or the weight of the rubber fuel line and filter put an additional load on it...
I know for a fact--and from experience--that it will seal itself if exposed to heat--like from a torch--and that it's very long lived in its meanderings through the passenger compartment, where it's cool and dark.  It's all original on both my 69 and 73.
Just a suggestion to consider.
But, we are still waiting for the answer to Jimk's question.  The plastic line was meant to be used with the mechanical pump pulling fuel through it, as opposed to putting an electric pump in the trunk and pushing fuel through.
A leak in the original configuration will suck air into the line and allow fuel to drain back to the tank when the engine is shut off.  A leak in that line with a pusher-pump will cause a Big gas leak.
  • Like 4
