Senna27 Posted October 31, 2022 Share Posted October 31, 2022 (edited) My car developed a front suspension rattle the other day. We put my car on the hoist and thoroughly checking all the suspension components. After seeing nothing obvious, we put the car back on the ground. If we grabbed the strut bar and shook the car, you could hear a clicking noise. As my buddy shook the car, I put my hand on the the nut at the top of the shock and felt some movement. That was it, the nut was loose. I couldn't find a torque spec. for the nut, so I used what I figured was a reasonable amount of force. A day later it was loose again. They're Koni Yellow Sport Adjustable shocks. There's a bearing at the top then a spacer, lock nut and the nut. I concerned that if I use too much force it will damage the bearing or make it difficult to turn the wheel. Anyone have a set up like this and know what the proper torque spec. should be? I suppose I could swap out that nut for a nyloc hex nut. Edited November 1, 2022 by Senna27 Quote Link to comment Share on other sites More sharing options...
tzei Posted October 31, 2022 Share Posted October 31, 2022 Found this on internet: Quote Link to comment Share on other sites More sharing options...
stephers Posted November 1, 2022 Share Posted November 1, 2022 You need a nyloc nut or at the very least a double nut set up. A single nut like that will work loose unless you blue loctite it A number of things to do to keep it tight. Thanks, Rick 2 Quote Link to comment Share on other sites More sharing options...
M3M3M3 Posted November 1, 2022 Share Posted November 1, 2022 49 minutes ago, stephers said: You need a nyloc nut or at the very least a double nut set up. A single nut like that will work loose unless you blue loctite it A number of things to do to keep it tight. Thanks, Rick this. gotta have nyloc or double nut. 1 Quote Link to comment Share on other sites More sharing options...
Senna27 Posted November 1, 2022 Author Share Posted November 1, 2022 16 hours ago, tzei said: Found this on internet: Thanks. My question is, do those torque specs apply regardless of the type of bearing/upper support mount one has? As you can see, mine is not stock. Quote Link to comment Share on other sites More sharing options...
Senna27 Posted November 1, 2022 Author Share Posted November 1, 2022 12 hours ago, stephers said: You need a nyloc nut or at the very least a double nut set up. A single nut like that will work loose unless you blue loctite it A number of things to do to keep it tight. Thanks, Rick Yeah, a nyloc would certainly make more sense. Thanks. Quote Link to comment Share on other sites More sharing options...
Solution tzei Posted November 1, 2022 Solution Share Posted November 1, 2022 8 minutes ago, Senna27 said: do those torque specs apply regardless of the type of bearing/upper support mount one has? As you can see, mine is not stock. Yes. Torques refers to threads - what they can endure. Your bearings inner race can take many times more force than that shaft/tread can take. She’ll be alright. nylock is good choise. I use em. Rear shocks has double nuts. 2 Quote Link to comment Share on other sites More sharing options...
Senna27 Posted November 1, 2022 Author Share Posted November 1, 2022 (edited) 20 minutes ago, tzei said: Yes. Torques refers to threads - what they can endure. Your bearings inner race can take many times more force than that shaft/tread can take. She’ll be alright. nylock is good choise. I use em. Rear shocks has double nuts. That makes sense, thanks. I'll use a nyloc and leave the lock-washer there for good measure. One more problem solved. 😊 Edited November 1, 2022 by Senna27 Quote Link to comment Share on other sites More sharing options...
