Quick rear hub question
Georges
Go to solution Solved by Georges,
  • Solution
I bought the correct type of puller ($60 on Amazon) like you guys recommended and it came right off. The other side had a new cotter pin and it slid off when I was just getting started. PO must have done something to that side. Lesson learned - use the correct tool.
 I did end up buying a new hub 🙁 . Luckily the stub was undamaged.
  • Like 5
  • Confused 1
  • Sad 1
Bent as an S hook.
I refreshed mine last year and one of them was a nightmare. Hub got every so slightly bent.
I put it in a metal lathe and got it straight again.
Car wont be running for at least 2 more years so dont know if it'll be an issue yet 😛
Perhaps you could use it as an ashtray now ?
42 minutes ago, Dudeland said:
I was expecting the same fights as mentioned earlier and as such got the hydraulic option on hot standby.  I am almost embarrassed to say that mine came off with a couple of blows from a dead blow hammer.
I'm hoping that is what will happen with mine. I will have a puller on standby though 🙂
Phil
1975 1602 with an M42 engine.
Project thread http://www.02forum.co.uk/viewtopic.php?f=11&t=14853#p107713
17 hours ago, uai said:
I have this setup
Homemade puller used in conjunction with the HAZET hydraulic insert.
It's totally easy to get anything off with the hydraulic thing.
Great looking tool!
Can you post a picture of the hydraulic portion that does the work ?
1 hour ago, Lorin said:
Great looking tool!
This is the old hazet hydraulic thing.
You clamp it between spindle and the part and turn the small screw on the side. when youve used the ~3/8 inch of travel you turn the small screw back and re-tighten the spindle of the puller and start over
Edited by uai
