GDI Posted October 29, 2022 Share Posted October 29, 2022 (edited) Changed the oils installed a new battery and then noticed this when I was doing the test ride. Edited October 29, 2022 by GDI Quote Link to comment Share on other sites More sharing options...
esty Posted October 29, 2022 Share Posted October 29, 2022 now it's broken in 1 Quote Link to comment Share on other sites More sharing options...
GDI Posted October 29, 2022 Author Share Posted October 29, 2022 (edited) I can verify it rolled over naturally - took this earlier in the day. Also appreciate any ideas on why that damn Brake light is always on! It stays on even if I short the reservoir or the Ebrake switch connections together. Irritating.. Edited October 29, 2022 by GDI Quote Link to comment Share on other sites More sharing options...
NYNick Posted October 29, 2022 Share Posted October 29, 2022 "Never seen rain" either. 2 Quote Link to comment Share on other sites More sharing options...
esty Posted October 29, 2022 Share Posted October 29, 2022 you sure the button is working under the e-brake handle 1 1 Quote Link to comment Share on other sites More sharing options...
Mike Self Posted October 30, 2022 Share Posted October 30, 2022 5 hours ago, esty said: you sure the button is working under the e-brake handle The bracket that holds the emergency brake switch (same switch as used for the overhead light in the headliner) is notoriously flimsy and easily bent. Were it a '76 I'd guess the problem was the brake system imbalance switch was either malfunctioning or actually detected an imbalance between the two brake circuits. But only 76s have that. Two other things--if you recently checked your brake fluid level (as I did) and added a little fluid (as I did), you may not have screwed the cap back on all the way (as I did) and the warning light remained on even after I had refilled the reservoir. Finally, pull the little float in the reservoir, dry it off and hold it up to the light. If there's brake flulid inside, it's gonna ride low and make your warning light go on. The float in my '73 did just that a few years ago and I had to replace it. mike PS, My '73's odometer hit 272272 today...a palindromic number. 1 Quote Link to comment Share on other sites More sharing options...
GDI Posted October 30, 2022 Author Share Posted October 30, 2022 11 hours ago, NYNick said: "Never seen rain" either. I know it has seen rain - I have driven it in rain! But all records since the early ‘80s indicate the milage is accurate. So about 100,025 miles as she sits today (not that it matters much) Quote Link to comment Share on other sites More sharing options...
GDI Posted October 30, 2022 Author Share Posted October 30, 2022 11 hours ago, esty said: you sure the button is working under the e-brake handle I actually shorted those connection and no luck Quote Link to comment Share on other sites More sharing options...
GDI Posted October 30, 2022 Author Share Posted October 30, 2022 5 hours ago, Mike Self said: The bracket that holds the emergency brake switch (same switch as used for the overhead light in the headliner) is notoriously flimsy and easily bent. Were it a '76 I'd guess the problem was the brake system imbalance switch was either malfunctioning or actually detected an imbalance between the two brake circuits. But only 76s have that. Two other things--if you recently checked your brake fluid level (as I did) and added a little fluid (as I did), you may not have screwed the cap back on all the way (as I did) and the warning light remained on even after I had refilled the reservoir. Finally, pull the little float in the reservoir, dry it off and hold it up to the light. If there's brake flulid inside, it's gonna ride low and make your warning light go on. The float in my '73 did just that a few years ago and I had to replace it. mike PS, My '73's odometer hit 272272 today...a palindromic number. Thanks, Mike - I’ll check those things out today! Quote Link to comment Share on other sites More sharing options...
