pd_55 Posted October 19, 2022 Share Posted October 19, 2022 So I got my Getrag 245 5-speed in with my motor swap a couple months ago and everything seemed to be dry shifting fine, after I changed my shifter. Finally got it out for a road test and that's where things got questionable. As I went through the gears, I went 4th to 5th and it was actually 3rd. Trying the pattern, there is a definite difference between 3rd and 5th, meaning it's "down and over". But it is clearly 3rd when driving. And there is a "6th" gear, meaning that I can go "up and over" from 4th to what seems to be another gear, but again it's only 4th. Does anyone know what this could be about? Again, it's clear that it's going into where 5th should be. And it did go into 5th with the old shifter, it was just very difficult. As always, any imparted knowledge is appreciated. Paul Quote Link to comment Share on other sites More sharing options...
tech71 Posted October 20, 2022 Share Posted October 20, 2022 (edited) 7 hours ago, pd_55 said: it's clear that it's going into where 5th should be How do you know that? Seems clear it’s not going into where 5th should be. You changed your shifter?with what? Clearance/binding issues somewhere in the linkage, seems like it has to be. Possibly between the shift rod joint and whatever you are using as a platform Edited October 20, 2022 by tech71 Quote Link to comment Share on other sites More sharing options...
paulyg Posted October 20, 2022 Share Posted October 20, 2022 Yes post pics of your shifter setup as-installed. It is totally possible that the geometry being off is messing with the shift pattern. 5th is not "up and over," as far as the transmission is concerned- it's "twist clockwise and pull out." Depending on the geometry something totally different might be happening at the selector rod than you think. Quote Link to comment Share on other sites More sharing options...
pd_55 Posted October 21, 2022 Author Share Posted October 21, 2022 Sorry, haven’t been able to get good pics, but I did ease off the set screws on the shifter and now 5th seems to engage, but it seems waaay over from 3rd. I’ve only ever had the 4 speed, so not sure if that is normal or not. 1st through 4th seem very close compared. Haven’t gone for a highway drive yet, but hoping it engages properly. Still needs to visit to the tuner in November, so don’t want to put too many miles on it before that. Have a Coolerworx chassis mount shifter and seems to have enough play without binding, but need another body to so I can check it from underneath. Quote Link to comment Share on other sites More sharing options...
tech71 Posted October 21, 2022 Share Posted October 21, 2022 (edited) 48 minutes ago, pd_55 said: Have a Coolerworx chassis mount shifter and seems to have enough play without binding, I googled them, okay then, forget anything I said. Not sure about a fixed shift lever linked to components with a noticeable amount of relative movement (that varies with power application). Good luck any way and make sure your engine/trans mounts are in good condition. Edited October 21, 2022 by tech71 2 Quote Link to comment Share on other sites More sharing options...
2002iii Posted October 21, 2022 Share Posted October 21, 2022 Sounds more like trouble with aftermarket short shifter than with the 245 transmission. I too had to Google coolerworx, I couldn't find a 2002 specific version. I also noticed in a review someone mentioned solid motor and transmission mounts!!! Quote Link to comment Share on other sites More sharing options...
TobyB Posted October 21, 2022 Share Posted October 21, 2022 coolerworx? nerp, ditch it. Andrew and I will chase each other to the grave fighting about this (with nerf guns and pool noodles) but shorten an early shifter, mount it to the back of the transmission, and all will be well again. By design, it ends up with a pretty short throw. It works great. And it's 'vintage'! t 5th gear on the 245 takes a HUMONGOUS amount of force to get into the gate- you're probably just moving the engine. Reverse is pretty much the same... Quote Link to comment Share on other sites More sharing options...
pd_55 Posted October 21, 2022 Author Share Posted October 21, 2022 @2002iii I do have poly AKG motor and trans mounts, not the “race” hardness, but certainly stiffer than HD rubber. The only thing that I needed to customize on the shifter was to shim it up about 3/8” as it had the DSSR angled down so it wasn’t level. A long test drive will help me dial it in better and find out if 5th engages correctly. Just didn’t know if I was missing something with the 245. Thanks. Quote Link to comment Share on other sites More sharing options...
kine8282 Posted November 3, 2022 Share Posted November 3, 2022 @pd_55 Did you ever find a solution for this? I’m having issues with my tranny not disengaging when it’s supposed to be in neutral. I too am using a chassis mounted shifter from AKG. Hoping to learn from what you’re going through. Quote Link to comment Share on other sites More sharing options...
pd_55 Posted November 4, 2022 Author Share Posted November 4, 2022 @kine8282 My issue started when I went from the factory 4 spd to the Getrag 245 5 spd. With the AKG, it was ordered for the 4 spd, so not sure if there are any differences with the shifter itself for a 5 spd. I know the DSSR length is different. What I saw was that there was some binding between the shaft and lower body of the shifter when it needed to go far left into reverse and far right for 5th. But again, when I had the 4 spd, there were no issues with the AKG. Quote Link to comment Share on other sites More sharing options...
kine8282 Posted November 4, 2022 Share Posted November 4, 2022 Gotcha. In my research to try and fix my problem. I ran into info on the detent spring plunger sometimes being out of alignment especially when going into reverse. I dunno. Worth a try in your situation. Mine is that my tranny isn’t in neutral. It might be the AKG shifter being out of alignment but it’s definitely a puzzling problem. Good luck, I’ll be keeping an eye on this post Quote Link to comment Share on other sites More sharing options...
pd_55 Posted November 4, 2022 Author Share Posted November 4, 2022 @kine8282 You have to drop the tranny for that detent pin, I think. If you take out the 3 bolts holding the shifter in and get it in neutral, it should sit nice and align itself. Then maybe drill new mounting holes? My issue seems to be sorted now. I had to move the shifter around and adjust the limiting screws that are on the shifter. Goes into gear now. 1 Quote Link to comment Share on other sites More sharing options...
kine8282 Posted November 4, 2022 Share Posted November 4, 2022 @pd_55 Looks your problem is solved , that’s great. Mine is still on going.m, I’m 98% sure the tranny is in neutral. It just doesn’t act like it at least to me. Can you spin your rear wheel by hand? Quote Link to comment Share on other sites More sharing options...
pd_55 Posted November 4, 2022 Author Share Posted November 4, 2022 @kine8282 Yes, wheels do spin by hand. Quote Link to comment Share on other sites More sharing options...
