its55 Posted October 14, 2022 Share Posted October 14, 2022 Just curious to know if any of you guys have used this stuff or might (or might not) recommend it? Amazon.com: VP Racing Fuels Madditive Cool Down - Radiator Systems Temperature Decrease 16 Ounces for All Radiators. Decreases Engine Temps up to 30 Degrees : Automotive Quote Link to comment Share on other sites More sharing options...
Tommy Posted October 14, 2022 Share Posted October 14, 2022 Is it different than Redline Water Wetter? That I'm using in my racecar as glykol is forbidden nowdays on tracks around here. Redline advertises -20 degrees which is way optimistic but it has some effect. I'm using the stuff just to avoid corrosion. I would recommend using something instead plain water. Then if you have a small heating capacity issue you might try something like that to see if it helps. 1 Quote Link to comment Share on other sites More sharing options...
its55 Posted October 14, 2022 Author Share Posted October 14, 2022 5 minutes ago, Tommy said: Is it different than Redline Water Wetter? That I'm using in my racecar as glykol is forbidden nowdays on tracks around here. Redline advertises -20 degrees which is way optimistic but it has some effect. I'm using the stuff just to avoid corrosion. I would recommend using something instead plain water. Then if you have a small heating capacity issue you might try something like that to see if it help I was considering adding this to the specified coolant just for some added temperature reduction. Quote Link to comment Share on other sites More sharing options...
