Pablo M Posted October 14, 2022 Share Posted October 14, 2022 Getting delivery of my new-to-me 1972 2002tii on Monday (from TN, to SoCal). Bought from second owner, but it’s sat for the last 10 years with only about 400 miles in that time. Getting full records of maintenance but nothings been done in 10 years. I figure most rubber needs replacing. Starting with tires and brake lines (stainless steel). Timing belt and WP probably good idea (are m10’s interference engine like m20’s?). what else should I do? Goal is a second daily that’s a fun canyon/track car. Quote Link to comment Share on other sites More sharing options...
dlacey Posted October 14, 2022 Share Posted October 14, 2022 No timing belt to worry about, otherwise I agree that many rubber parts will need attention. Fuel tank will need some service, fuel pump likely will need replacement. But I would expect that after some simple prep on fuel and ignition it will start and run fine. Quote Link to comment Share on other sites More sharing options...
Pablo M Posted October 14, 2022 Author Share Posted October 14, 2022 15 minutes ago, dlacey said: No timing belt to worry about, otherwise I agree that many rubber parts will need attention. Fuel tank will need some service, fuel pump likely will need replacement. But I would expect that after some simple prep on fuel and ignition it will start and run fine. Car runs fine as is. I’ve seen videos of it running as of tonight and seems solid. I’ll assess more in depth when I have it in hand. I’m most worried about cooling system really. Quote Link to comment Share on other sites More sharing options...
1936spyder Posted October 14, 2022 Share Posted October 14, 2022 Brake system will probably require the most attention and work. Presumably the brakes have seized so rebuilt calipers, fresh pads and shoes, new lines, etc. Master & slave cylinder inspect for leaking, replace if necessary. Drain and flush both the radiator and gas tank, inspect and replace any fuel lines that need doing so, same with radiator hoses & thermostat. Obviously new tires. You said in a video that the car seems to run fine, so does that mean that the PO performed a basic tuneup? Did they inspect and test the ignition system at that time as well? If not, you obviously have to do all of those things and replace any parts that need doing so. Regarding the gas tank, check the O-ring as well as the hoses in the trunk as they might very well have deteriorated, and if so, can not only cause gas to leak, but create quite a strong odor which will make its way to the interior cabin. This is a notorious issue with virtually all 02’s Check/inspect lights, bulbs, dash cluster, horns. Have fun… Quote Link to comment Share on other sites More sharing options...
d.hitchcock Posted October 14, 2022 Share Posted October 14, 2022 Paul Wegweiser has a bunch of solid advice for reviving a dormant tii. He gave a fantastic presentation at 02 Fest about this a couple years back. For instance ... "This is how a resurrection really feels" WWW.MAXIMILLIANBLOG.COM - Hold Steady The beautiful cars we admire at car shows and auctions don't always start out beautiful. The "new car smell" for which many of us long, has often been replaced by rotting and brittle dried out horse hair (pssst! It's actually coconut husks on old BMWs!) and rodent... Quote Link to comment Share on other sites More sharing options...
Stevenc22 Posted October 14, 2022 Share Posted October 14, 2022 Replace the fuel lines from the tank forward, those are probably crusty and you dont want a fuel leak. Flush the radiator and block, new coolant. New brake fluid. New Spark Plugs Oil Change That aught to be enough for you to then drive the vehicle and determine what else needs doing. 1 Quote Link to comment Share on other sites More sharing options...
JsnPpp Posted October 14, 2022 Share Posted October 14, 2022 (edited) Literally replace everything rubber in the engine compartment + brake system. Even if it looks ok, unless you have a recent receipt for it being replaced. Yes it will add up a bit but not much in the big picture (I have no idea how much you paid but the advice is the same regardless). You don't want to be stranded or worse, injured or even worse injure someone else because a brake line "looked ok". It's fun too and is more time to bond with the car (unless you are paying someone else to do it). ~Jason Edited October 14, 2022 by JsnPpp 1 Quote Link to comment Share on other sites More sharing options...
John_in_VA Posted October 14, 2022 Share Posted October 14, 2022 7 hours ago, dlacey said: No timing belt to worry about, otherwise I agree that many rubber parts will need attention. But the Kugelfischer pump has a rubber belt that should be examined. 3 Quote Link to comment Share on other sites More sharing options...
ColinK Posted October 14, 2022 Share Posted October 14, 2022 1 hour ago, John_in_VA said: But the Kugelfischer pump has a rubber belt that should be examined. if it sat for 10+ years, i'd just replace the belt along with all the fuel hoses (with a the correct fuel hoses) and replace the fuel filter by the radiator. 1 Quote Link to comment Share on other sites More sharing options...
Pablo M Posted October 15, 2022 Author Share Posted October 15, 2022 Thanks everyone. I have some more info. -brakes were recently rebuilt and new fluid very recently. -mechanical fuel pump has been recently rebuilt. there were a few other things and he has a list for me. -he has all receipts AND the original window sticker, manuals, etc. coming with car. I got a video of them driving it onto the trailer this afternoon as well. once I get the receipts I’ll create a binder and log all the repairs. Then I’ll have a better idea. But I’m with you on rubber bits, particularly fuel lines. We’re very sensitive in our house as my sons e30 caught fire last July (he rebuilt it). I’ll be doing all the work myself. solid info. Thanks everyone. 3 Quote Link to comment Share on other sites More sharing options...
Mark92131 Posted October 15, 2022 Share Posted October 15, 2022 12 hours ago, Pablo M said: -mechanical fuel pump has been recently rebuilt. Not on a Tii. But good advice to replace rubber fuel lines and check the Kugelfischer belt. Mark92131 Quote Link to comment Share on other sites More sharing options...
Steve Tochi Posted October 15, 2022 Share Posted October 15, 2022 Congratulations Pablo, Even though you have a receipt stating it was rebuilt, I'd really like over that KF for leaks when its running, lines and o-ring suction valves. I've had a few leaks pop up now and again. And carry a fire extinguisher! ha ha Steve Quote Link to comment Share on other sites More sharing options...
Mark92131 Posted October 15, 2022 Share Posted October 15, 2022 16 hours ago, Pablo M said: -mechanical fuel pump has been recently rebuilt. My bad, you were talking about Kugelfisher being rebuilt, not the electrical fuel pump feeding the Kugelfisher. Mark92131 Quote Link to comment Share on other sites More sharing options...
