lawddf Posted October 4, 2022 Share Posted October 4, 2022 I currently have a Bosch AL45X alternator on my 73tii. Sometimes when I start the car the voltmeter stays around 12 volts, then eventually the alternator will wake up and raise the voltage to approximately 14 volts. Sometimes I have to rev the engine to get the alternator to charge. The fan belt is tight and not slipping and I added a ground wire from the alternator to the chassis ground which did not make a difference. 1) I've looked for a replacement AL45X but they all seem to be out of stock or NLA. Is there a similar alternator that is available for a reasonable price that will bolt up in place of the AL45X without significant mods? 2) Should I try replacing the voltage regulator and if so where do I get one? Quote Link to comment Share on other sites More sharing options...
tech71 Posted October 4, 2022 Share Posted October 4, 2022 (edited) First check and clean voltage regulator ground points, remove screws holding voltage regulator to inner fender, clean where they mate up with a wire brush/bit of sandpaper. Clean the blade connectors as well. You sure alternator is properly grounded to the engine with at least a 12GA wire (10 GA is better) and engine is properly grounded to chassis? Dont just look at them and say "looks good" Clean them!😉 There is probably an alternator/starter repair shop around your area, oft times a rather scruffy old building staffed by an equally scruffy/gruffy old geezer. They can test/repair your alternator. Might be nothing more than worn brushes, Edited October 4, 2022 by tech71 2 Quote Link to comment Share on other sites More sharing options...
bergie33 Posted October 4, 2022 Share Posted October 4, 2022 I went with a rebuilt AL41x. It is from an E12 5-series or an early 6-series. Seemed to be an easier fit for a Tii than many other upgrades. Not a huge amperage upgrade, but at 65 amps, it is almost 50% more. 1 Quote Link to comment Share on other sites More sharing options...
