M4202 Posted September 28, 2022 Share Posted September 28, 2022 (edited) My m42s dipstick popped out, I checked its not producing white smoke , or down on power , or excess oil consumption , or oil in the intake , so its either the pcv valve or the dipstick gasket rings are bad , before i replace the dipstick , i wanted to test the pcv valve is a healthy pcv valve if i open the oil fill on the valve cover is it supposed to be pushing out or sucking in ? And what does a bad pcv valve suck in or push air out ? Also where is the location of the pcv valve on this engine? I cant seem to find it online . Thank you for you time . (My 02 has A M42 swap from a 1991 318 is) Edited October 1, 2022 by M4202 Clarification Quote Link to comment Share on other sites More sharing options...
JsnPpp Posted September 28, 2022 Share Posted September 28, 2022 We have a '91 318iS and I don't believe there is one on this engine. A lot of hoses however, especially if you haven't fixed the "mess under the intake" as it's called. WHen you say it popped out, you mean it keeps popping out every time you push it back in? I'd start with the oil dipstick seal, may just be loose? Jason Quote Link to comment Share on other sites More sharing options...
M4202 Posted September 28, 2022 Author Share Posted September 28, 2022 Took the car on the highway for the first time , lots of high rpm for a while like 4 plus for minutes at a time , parked it . The next day there was some oil underneath the car and the dipstick was half way out checked down the street and was dripping oil as far as i could see . Any ideas Im trying to diagnose the issue before i point the parts cannon at it . Quote Link to comment Share on other sites More sharing options...
JsnPpp Posted September 29, 2022 Share Posted September 29, 2022 (edited) So the oil leak is out of the dipstick tube I take it? Something isn't letting the pressure out. How about the vent tube at the top of the head? It threads down under the intake. ~Jason Edited September 29, 2022 by JsnPpp 1 Quote Link to comment Share on other sites More sharing options...
M4202 Posted September 29, 2022 Author Share Posted September 29, 2022 Ok thank you ill start there . Quote Link to comment Share on other sites More sharing options...
JsnPpp Posted September 29, 2022 Share Posted September 29, 2022 This thread mentions crankcase ventilation but isn't specific: My dip stick keeps popping out WWW.BIMMERFORUMS.COM Well since I traded cars a few months ago I've been coming across some small issues with my car the old owner didn't tell me about one being some how and some way my dip stick pops out under a have load and will result in the car idle and running funny what may cause this... 1 Quote Link to comment Share on other sites More sharing options...
John76 Posted September 29, 2022 Share Posted September 29, 2022 So... what should be happening in a normal 4-cylinder engine?? My car blows (slightly) when the oil filler cap is removed. When the dipstick is removed, the crankcase pulses at idle, then sucks (slightly) above idle speeds. Quote Link to comment Share on other sites More sharing options...
jgerock Posted September 30, 2022 Share Posted September 30, 2022 On a M42 engine, there is a simple o ring that seals the tube to the front of the engine. Quote Link to comment Share on other sites More sharing options...
M4202 Posted September 30, 2022 Author Share Posted September 30, 2022 I found some good things out and some bad things . Good things the only m42s that had pcv valves were from 1/94 to the end of the production run. Mines a 91 so no pcv valve , will post proof document on that later next week or so . I used my Endo scope to look at the valve cover breather port open, upper intake breather clear too , will post pictures when i post other docs . Who ever did the " mess under the intake delete " on this motor ,half a**ed it deleted the heater plate but not the mess of vacuum lines under the intake which there's a huge leak i think in the vacuum system because of that will pull the intakes off and confirm ,but i think the coolant hose was rerouted properly . Also there's a vacuum hose that runs from the valve cover to the upper intake breather hole , and there like a reverse flow block off fitting i think that's whats in there , well i think i found my problem , that's getting deleted for a catch can . Any recommendations for a catch can for this set up ? Also i learned the proper way to route those hoses is from the valve cover to the throttle body , and from the icv end to the upper intake breather . On a side note could i modify the header to make it easier to find for the next guy dealing with this problem ? adding the dipstick popping out part so the next person could easily find this ? Quote Link to comment Share on other sites More sharing options...
ray_ Posted October 1, 2022 Share Posted October 1, 2022 9 hours ago, M4202 said: On a side note could i modify the header to make it easier to find for the next guy dealing with this problem ? adding the dipstick popping out part so the next person could easily find this ? Click the three dots (...) on your first post (I suppose) and edit the subject line. Cheers, Quote Link to comment Share on other sites More sharing options...
'76mintgrün'02 Posted October 1, 2022 Share Posted October 1, 2022 11 hours ago, ray_ said: Click the three dots (...) on your first post (I suppose) and edit the subject line. Cheers, I was sure Ray was going to advise you to change the spelling in the title to advice. Are you feeling okay, Ray? Tom Quote Link to comment Share on other sites More sharing options...
ray_ Posted October 1, 2022 Share Posted October 1, 2022 32 minutes ago, '76mintgrün'02 said: I was sure Ray was going to advise you to change the spelling in the title to advice. Are you feeling okay, Ray? Tom I seem to have lost my... grip. 😜 Quote Link to comment Share on other sites More sharing options...
TobyB Posted October 1, 2022 Share Posted October 1, 2022 Hey, I found a pair of grips in the junkyard just the other day. Shall I send them to you? They're not a full circle, tho, only Crescent... t has several M42's, but they're post 1-94 so have EGR passageways. Also has an oil filler cap modified for a gauge becaus also has M54s with their... special qualities. Quote Link to comment Share on other sites More sharing options...
ray_ Posted October 1, 2022 Share Posted October 1, 2022 3 hours ago, TobyB said: Hey, I found a pair of grips in the junkyard just the other day. Shall I send them to you? They're not a full circle, tho, only Crescent... t has several M42's, but they're post 1-94 so have EGR passageways. Also has an oil filler cap modified for a gauge becaus also has M54s with their... special qualities. I need to get around to emailing Irwin regarding my little Vise Grips of which I broke the release arm. I assume they are warranted forever... Cheers, Quote Link to comment Share on other sites More sharing options...
M4202 Posted October 1, 2022 Author Share Posted October 1, 2022 Thank you , first time posting on a forum . Also whats the problem with m54's? Quote Link to comment Share on other sites More sharing options...
