2002Scoob Posted September 28, 2022 Share Posted September 28, 2022 (edited) So I'm well underway with the rear subframe rebuild for Brunhilde. I found a complete rear subframe for cheap that beyond the superficial, was pretty much rust-free that's getting sandblasted and painted in urethane epoxy gloss-black to match the front-end rebuild. And in prep, I dropped an order at W&N to pickup a handful of hardware/new bearings, and... those 'motorsport' rear subframe pushrod/straps. Beefy. But what's got me wondering, is that there's two slotted-esque holes on that lower end vs. the original 1. I called W&N and spoke to a fella on the phone who said you only use one of them, but then why two? Since the parts are already at the blasters/painters I can't play legos, has anyone installed these and can offer comment as to the two holes? Is there facilities to use both? Cheers, -J Edited September 28, 2022 by 2002Scoob Quote Link to comment Share on other sites More sharing options...
AceAndrew Posted September 28, 2022 Share Posted September 28, 2022 It's a strap from an E9 coupe, hence the fitment variability. 3 Quote Link to comment Share on other sites More sharing options...
Ian Posted September 28, 2022 Share Posted September 28, 2022 That looks like a decent upgrade. Quote Link to comment Share on other sites More sharing options...
danco_ Posted September 28, 2022 Share Posted September 28, 2022 Upgrading what exactly? Does this replacement part increase rigidity somewhere? I have seen Kooglewerk's new offering but I'm not sure I understand it's importance aside from aesthetics. 1 Quote Link to comment Share on other sites More sharing options...
AceAndrew Posted September 28, 2022 Share Posted September 28, 2022 I have seen higher torque apps begin to ovalize holes or buckle the strap. I've also stated it's one of the parts I'd planned on making but never got around to it. There is no structural reason for adjustability. The part largely sees axial loads, so simply increasing the cross-sectional area would reduce deflection (hence my former plan to use oval tubing with angle-cut/bent ends drilled for bolts. Simple and effective). Ryan, side note .... as talking to the TRD rep at the CPP Engr. Career Fair on Friday ... he's apparently a fan of SoC, small world. 1 Quote Link to comment Share on other sites More sharing options...
uai Posted September 28, 2022 Share Posted September 28, 2022 There are older and newer ones of these. The older ones need a little bending and they’re fine. Then you need two new holes in the floor with reinforcement and threads on the inside. The newer Style doesn’t fit properly. 1 Quote Link to comment Share on other sites More sharing options...
AceAndrew Posted September 28, 2022 Share Posted September 28, 2022 1 minute ago, uai said: The newer Style doesn’t fit properly. Because it's not a "newer" style ... it's lifted from a different application (see my comment re: E9). Quote Link to comment Share on other sites More sharing options...
uai Posted September 28, 2022 Share Posted September 28, 2022 (edited) No. These two have the same part# Edited September 29, 2022 by uai 1 Quote Link to comment Share on other sites More sharing options...
AceAndrew Posted September 28, 2022 Share Posted September 28, 2022 Interesting; still the different application as noted. As for drilling an extra hole in the 2002 chassis rather than running a bolt-in upgraded substitute... to each their own. EDIT: Here's a picture as found on the E9 coupe via Markus on the coupe board. https://e9coupe.com/forum/threads/rear-subframe-question.24717/post-344226 Quote Link to comment Share on other sites More sharing options...
uai Posted September 28, 2022 Share Posted September 28, 2022 Here’s the old style with orange Sticker after bending Quote Link to comment Share on other sites More sharing options...
tzei Posted September 28, 2022 Share Posted September 28, 2022 I took mine out of scrapped NK. Made new reinforced mounts for two front bolts. Quote Link to comment Share on other sites More sharing options...
jp5Touring Posted September 28, 2022 Share Posted September 28, 2022 Danjer Motorsports makes one but sold out. https://www.danjermotorsports.com/collections/suspension/products/rear-sub-frame-braces Quote Link to comment Share on other sites More sharing options...
AceAndrew Posted September 28, 2022 Share Posted September 28, 2022 With great respect to Danjer, based on the axial compression and tension forces this sees, it is not a part that should be slotted (at the bolt or along it's length), nor made of aluminum. In my worthless two cents we have three options. One that doesn't fit, one that offers unneeded features, and one that doesn't offer enough. Again, I'm not making parts in the foreseeable future .... but if one would make it as I've outlined above, they'd have the goldilocks zone for fitment, function, and cost. 2 Quote Link to comment Share on other sites More sharing options...
uai Posted September 28, 2022 Share Posted September 28, 2022 (edited) Here it's in the FIA homologation Form 5258 found the pics. I've recently had an unpleasant Drift over a high curb (on the bolt that holds the Rear axle). I was very greatful to have these. Without them damage to the car would have been much worse. Still needed a BFH and had to re-weld some stuff to get things straight again. Here you can see that the Rear axle attachement got bent. Welding opened A lot of the part was scraped down in this mishap Right side lost some of it's material After the repair Edited September 28, 2022 by uai 4 1 Quote Link to comment Share on other sites More sharing options...
jimk Posted September 28, 2022 Share Posted September 28, 2022 1 hour ago, AceAndrew said: With great respect to Danjer, based on the axial compression and tension forces this sees, it is not a part that should be slotted (at the bolt or along it's length), nor made of aluminum. +1 and not a flat bar. 3 Quote Link to comment Share on other sites More sharing options...
