pd_55 Posted September 27, 2022 Share Posted September 27, 2022 I had this issue a couple years back and figured it out. But can’t seem to recall it now. Refreshing a leaking steering box, but not able to get the steering shaft to move back to move/remove the coupler. I have a solid steering coupler, so the shaft does need to move back a few inches to remove it. From what I remember, the only thing holding it in place was the coupler, but is there anything else on the column that needs to be loosened to get the shaft to move back? Maybe someone can help jog my memory. Thanks. Quote Link to comment Share on other sites More sharing options...
tzei Posted September 27, 2022 Share Posted September 27, 2022 Column firewall support and chassis bolts (s/lock assembly) under the dashboard. Quote Link to comment Share on other sites More sharing options...
Stevenc22 Posted September 27, 2022 Share Posted September 27, 2022 Are you trying to split the steering shaft around the normally rubber guibo? If so you remove the lock bolts from either side of the guibo and then beat on the sliding collar to get it to slide away. Make sure you completely remove the lock bolts as the shaft is keyed for the bolt and wont slide with the bolt installed. Quote Link to comment Share on other sites More sharing options...
pd_55 Posted September 27, 2022 Author Share Posted September 27, 2022 @Stevenc22 So I had swapped out the guibo for a solid, universal joint style coupler. I removed the set screws and it slides easy on both shafts, but I can’t move the upper shaft into the cabin. I know there is the bracket just after the firewall, but that shouldn’t hold the shaft tight. Doesn’t seem to be anything that holds the inner shaft securely except the guibo/coupler. Does it just need to be hammered harder to get it to move? Quote Link to comment Share on other sites More sharing options...
tzei Posted September 27, 2022 Share Posted September 27, 2022 Inner shaft is locked by its bearing bracket (?) at the top. Just ease clamp from firewall support & undo column bolts. Quote Link to comment Share on other sites More sharing options...
pd_55 Posted September 27, 2022 Author Share Posted September 27, 2022 @tzei I removed the upper and lower shrouds behind the steering wheel, so are there additional column bolts to undo? And not sure of the clamp from the firewall support. Do you have a pic of that? Thanks. Quote Link to comment Share on other sites More sharing options...
tzei Posted September 27, 2022 Share Posted September 27, 2022 Clamp and bolts, positions #5 & #15 Steering column-trim panel/attach.p. | BMW 1502-2002tii 2002 M10 Europe BMWFANS.INFO Steering column-trim panel/attach.p. | BMW 1502-2002tii 2002 M10 Europe Quote Link to comment Share on other sites More sharing options...
pd_55 Posted September 27, 2022 Author Share Posted September 27, 2022 @tzei Thanks. I’ll try to loosen these tonight and see if I can move the shaft. Quote Link to comment Share on other sites More sharing options...
pd_55 Posted September 28, 2022 Author Share Posted September 28, 2022 @tzei No dice on the shaft moving with everything loosened. To clarify, I’m just wanting the actual steering shaft/rod to be able to be moved back. I don’t need to remove the column or tube that shaft is in. I’m completely stumped on why it wouldn’t be free. I didn’t want to go down to road of dismantling the whole column area, but maybe that’s what’s needed? It should move freely once it’s properly loose, correct? Do the (2) bolts under the column assembly need to be completely removed or can they just be loose? I’ve removed them before and it can be a challenge getting them back in. With them out, the entire assembly is free from the dash. Quote Link to comment Share on other sites More sharing options...
tzei Posted September 28, 2022 Share Posted September 28, 2022 To move shaft tube has to move too unless you dissassembe everything under the steering wheel. Easier to move whole column in order to move shaft to get out from the coupler. Two bolts has to come out completely. 1 Quote Link to comment Share on other sites More sharing options...
jimk Posted September 28, 2022 Share Posted September 28, 2022 Changing from the OE guibo sure made things difficult. Quote Link to comment Share on other sites More sharing options...
pd_55 Posted September 28, 2022 Author Share Posted September 28, 2022 @jimk The solid coupler is actually much easier to maintain, but does require the shaft to be able to be moved unfortunately. So much like every other modification I’ve done, always adds some extra complexity. Sounds like the bolts will come out and will move it the difficult way. Quote Link to comment Share on other sites More sharing options...
TobyB Posted September 28, 2022 Share Posted September 28, 2022 Are you expecting the shaft to come out of the column tube? Then you have to disassemble the bearing at the top of the tube, underneath the steering wheel. That bearing positively locates the shaft relative to the tube. t 1 Quote Link to comment Share on other sites More sharing options...
Son of Marty Posted September 28, 2022 Share Posted September 28, 2022 Since no one has mentioned it, you also need to have the wheel unlocked. Quote Link to comment Share on other sites More sharing options...
pd_55 Posted September 28, 2022 Author Share Posted September 28, 2022 Thanks all. I did need to pull the (2) bolts holding the column assembly and pull everything back as one. Now trying the get the nut off that holds the steering arm to the box. I should have taken it off while everything was still on the car though. Might have made it easier. Now to the box reseal. This and the shifter install and those should be the last items to make it mostly roadworthy….hopefully. Thanks for all the advice. Paul Quote Link to comment Share on other sites More sharing options...
