Tom Johnson Posted September 26, 2022 Share Posted September 26, 2022 DOOR CLIPS :I have rep;aced the clips that hold the lower trim to the door . The trim piece does notfit flus to the door because the clip is larger (wider) than the old one . I bought the clips from Roger`s tii quite a while ago . I am wondering if anyone else has had this problem and if they have found a different clip or a solution to the challenge Quote Link to comment Share on other sites More sharing options...
bergie33 Posted September 26, 2022 Share Posted September 26, 2022 Are they the white clips that are actually made for different BMWs, or are they the correct black clips? Quote Link to comment Share on other sites More sharing options...
Mike Self Posted September 26, 2022 Share Posted September 26, 2022 31 minutes ago, bergie33 said: Are they the white clips that are actually made for different BMWs, or are they the correct black clips? I think Tom is referring to the "knee molding" on modell 71 and later cars' doors. AFAIK the clips you're referring to are for the rocker panel trim. The original black ones, and the later (and larger) white clips that I think were meant for something on an E21. Quote Link to comment Share on other sites More sharing options...
Tom Johnson Posted September 26, 2022 Author Share Posted September 26, 2022 they are white . The trim piece does not touch the door Quote Link to comment Share on other sites More sharing options...
bergie33 Posted September 26, 2022 Share Posted September 26, 2022 2 hours ago, Mike Self said: I think Tom is referring to the "knee molding" on modell 71 and later cars' doors. AFAIK the clips you're referring to are for the rocker panel trim. The original black ones, and the later (and larger) white clips that I think were meant for something on an E21. Yes, Mike, your right. I was thinking the rocker trim. Quote Link to comment Share on other sites More sharing options...
