Dieter01 Posted September 19, 2022 Share Posted September 19, 2022 (edited) Hi there, I drive a 72 BMW 2002 ti and have a question…. When I accelerate everything works fine untill I reach about. 3000 revs…. Then it does not really want to go any higher….. As if there is a rev limiter n the car…. There are two double Weber carbs in it and a 123 ignition…. Any idears on this ? Thanks for your comments…. Edited September 19, 2022 by Dieter01 Quote Link to comment Share on other sites More sharing options...
Oldtimerfahrer Posted September 20, 2022 Share Posted September 20, 2022 Hi, I assume you have a normal 2002 that someone updated to the dual carb setup, so little guidance as its not a stock setup. If you really are experiencing a rev limiter in operation (not something else), it would have to come from the ignition system. Check the rotor in the distributor, that the correct rotor is installed. There is a rotor with a built-in rev limiter, would be nonsense even if it fit in the 123 distributor. The programmable 123 has a software activated rev limiter, which can be set to whatever RPM required. Check these two points. Andrew Quote Link to comment Share on other sites More sharing options...
jgerock Posted September 20, 2022 Share Posted September 20, 2022 +1 on Andrew’s response. Quote Link to comment Share on other sites More sharing options...
