KHANH NGUYEN Posted September 12, 2022 Share Posted September 12, 2022 Hi everyone, I am new member, just pulled out my 1973 tii. I looking for horn button switch on steering wheel. Mine is broken, Thanks Khanh Quote Link to comment Share on other sites More sharing options...
Mike Self Posted September 12, 2022 Share Posted September 12, 2022 Are you referring to the spring loaded contact that is pressed into the steering wheel and contacts the brass ring on the steering column? The same contact is used on the factory steering wheels as well as after market ones. You may be able to repair it, depending on what broke; if not, they should be available from the usual sources: Blunt, Maxmillian or W&N in Germany. mike Quote Link to comment Share on other sites More sharing options...
KHANH NGUYEN Posted September 12, 2022 Author Share Posted September 12, 2022 Thanks Mike, The only plastic cap top with BMW emblem is broken. I will check your sources Khanh Quote Link to comment Share on other sites More sharing options...
Conserv Posted September 12, 2022 Share Posted September 12, 2022 7 minutes ago, KHANH NGUYEN said: Thanks Mike, The only plastic cap top with BMW emblem is broken. I will check your sources Khanh A photo of your steering wheel might be helpful in determining where you should look for a solution. Regards, Steve Quote Link to comment Share on other sites More sharing options...
Mike Self Posted September 12, 2022 Share Posted September 12, 2022 1 hour ago, KHANH NGUYEN said: The only plastic cap top with BMW emblem is broken. This sounds like the horn button for an after market steering wheel, as all the US spec factory wheels (except for some 1970 cars) have either 3 or 3 spoke wheels with horn pushes in the spokes. The center cap just covers the mounting nut. Post a picture of your steering wheel and broken button. mike 1 Quote Link to comment Share on other sites More sharing options...
Conserv Posted September 12, 2022 Share Posted September 12, 2022 1 hour ago, Mike Self said: This sounds like the horn button for an after market steering wheel, as all the US spec factory wheels (except for some 1970 cars) have either 3 or 3 spoke wheels with horn pushes in the spokes. The center cap just covers the mounting nut. Post a picture of your steering wheel and broken button. mike +1 Yes, most likely an aftermarket wheel. Alternatively (a.) Khanh has a square taillight steering wheel on a round taillight car, or (b.) Khanh’s car is in a country where the title year is determined by the original registration date, and his car is, indeed, a square taillight… Like you say, “Post a picture!” Best regards, Steve Quote Link to comment Share on other sites More sharing options...
KHANH NGUYEN Posted September 15, 2022 Author Share Posted September 15, 2022 Here are some pictures of my wheel, yes it is an aftermarket steering wheel 1 Quote Link to comment Share on other sites More sharing options...
Mike Self Posted September 16, 2022 Share Posted September 16, 2022 That looks like a MOMO wheel and horn pushbutton. Surprisingly, those buttons are either an actual or a copy of the horn pushbutton Lucas supplied to innumerable Brit cars in the late 50s-60s. It was adopted by many aftermarket steering wheel makers--and in most cases the parts interchange. You should be able to find a replacement button from a steering wheel supplier; if you can't find one with the BMW center emblem, the buttons come apart so that you can swap the center pushes. mike 1 Quote Link to comment Share on other sites More sharing options...
KHANH NGUYEN Posted September 16, 2022 Author Share Posted September 16, 2022 Thank you so much Mike. Khanh Quote Link to comment Share on other sites More sharing options...
John_in_VA Posted September 17, 2022 Share Posted September 17, 2022 The wheel is a RAID Racemark - says so on the right spoke. Search for a replacement horn button with that information. Good luck! https://www.ebay.com/itm/175153175226 1 Quote Link to comment Share on other sites More sharing options...
