autokunst Posted September 12, 2022 Share Posted September 12, 2022 As I am cleaning up the rear springs on our 1968 1600-2, I first noticed the white paint stripe. BUT, then I saw what appears to be a second, brown stipe.?. And then I noticed there are some numbers and letters stamped into the spring that I can't identify (tried searches here on on the interweb). Anyone know what I might have here? Thanks in advance. White and brown? stripe? L&P 68114 H? L&P 66114 H? Quote Link to comment Share on other sites More sharing options...
visionaut Posted September 12, 2022 Share Posted September 12, 2022 Yeah, the striped colors indicated which spring variant. There’s a thread on here with what the differences are. ( search is your friend ). IIRC, there’s small spring variations based on vehicle type, for std, HD and Towing applications. Quote Link to comment Share on other sites More sharing options...
autokunst Posted September 12, 2022 Author Share Posted September 12, 2022 3 minutes ago, visionaut said: Yeah, the striped colors indicated which spring variant. There’s a thread on here with what the differences are. ( search is your friend ). Yes, the standard BMW stripes are red (only), white (only) and green (only). These are in order from lightest/softest to heaviest/stiffest. This was found through search and also in realoem. But I have not found anything about a second stripe, nothing about a brown stripe, and I cannot find anything about L&P. I suspect these are an aftermarket spring (like H&R), but from a company I have not identified yet. Google has not helped, either. Quote Link to comment Share on other sites More sharing options...
visionaut Posted September 12, 2022 Share Posted September 12, 2022 There’s an L&P Springs Manufacturing, LLC in Carthage, MO…. ??? Quote Link to comment Share on other sites More sharing options...
Gurmail Posted September 12, 2022 Share Posted September 12, 2022 What was once Red turned into Brown. You have White/Red rear springs made by L&P (they made springs for BMW 1600/02 back in the day). The "114" indicate the body type and "66" "68" indicate years of manufacture. Gurmail 2 2 Quote Link to comment Share on other sites More sharing options...
John76 Posted September 12, 2022 Share Posted September 12, 2022 I thought the front springs were the ones with two paint color marks and the rear springs only had one color. I think your rear springs are the mid-range (white paint). The brown you see might be a rust/scuff mark ... on all coils?? Quote Link to comment Share on other sites More sharing options...
autokunst Posted September 12, 2022 Author Share Posted September 12, 2022 6 minutes ago, Gurmail said: What was once Red turned into Brown. You have White/Red rear springs made by L&P (they made springs for BMW 1600/02 back in the day). The "114" indicate the body type and "66" "68" indicate years of manufacture. Gurmail Love it. Thanks for that history. I hadn't found any reference to springs with more than one stripe. Given two different dates of manufacture, and also I'm not sure the second spring has the second red/brown stripe, I am not certain I'll have the same rate on each side. But I won't worry about it. By the way, I have seen springs on early 70's BMWs with the red stripe that looked much more red than this. I had mentally ruled out the idea that this would be a faded red stripe. But it makes too much sense. Thanks again. @visionaut it seems the L&P spring manufacturing company in MO makes bed springs. ? 1 Quote Link to comment Share on other sites More sharing options...
autokunst Posted September 12, 2022 Author Share Posted September 12, 2022 5 minutes ago, John76 said: I thought the front springs were the ones with two paint color marks and the rear springs only had one color. I think your rear springs are the mid-range (white paint). The brown you see might be a rust/scuff mark ... on all coils?? I don't think so. It looks like a painted stripe with similar brush stroke appearance. But I should clean them up a bit more to reveal more. The spring on the right has been cleaned more than the left. That's the one I posted a close up of above. Quote Link to comment Share on other sites More sharing options...
Mike Self Posted September 12, 2022 Share Posted September 12, 2022 Per the factory shop manual, there were three different springs fitted to the front with the following stripes: green/blue --635-656 lbs white/blue --614-636 lbs red/blue -- 595-614 lbs for the rear: green: 776-803 lbs (everything but the automatic, which is 769-791 lbs) white: 750-776 lbs or 745-767 (automatic) red: 725-750 lbs or 717-741 (automatic) When I re-did my '69 and sanded/repainted the original springs, i reproduced the paint stripes as they came from the factory, and the front springs indeed did have two stripes. mike Quote Link to comment Share on other sites More sharing options...
autokunst Posted September 15, 2022 Author Share Posted September 15, 2022 Following up on this, first a clarification. The stamped letters and numbers in fact both read the same: L&P 68114 H. As someone suggested, I assume this is the manufacturer (L&P), the year (1968), and the car (type 114). H? Not sure. Presumably oem (see below), so original.?. I am just glad they are the same. And to follow up with the stripes, there are most definitely two distinct, painted on stripes per spring. One is white, the other appears brown. Could be an aged red, but I can't confirm or deny that. But here's the kicker. The blue shop manual illustrates rear springs with TWO STRIPES (despite the specifications from the manual that @Mike Self shared). BMW has been known to have unclear written information. I think this is a good example. 1 Quote Link to comment Share on other sites More sharing options...
'76mintgrün'02 Posted September 15, 2022 Share Posted September 15, 2022 34 minutes ago, autokunst said: The blue shop manual illustrates rear springs with TWO STRIPES This post by c.d.eisel shows two-stripe rear springs as heavy-duty. (my car came with the lightest heavy-duty springs installed, along with a trailer hitch). "one could alter the ride height of a heavier square tail light car by using really early round tail car springs. Springs are designed for body weight and options, like sunroof, emission controls, impact heavy bumpers, larger battery....... so later(big bumper) USA heavy cars would have different springs than the early stripped 1600/1602 trick is to find unmolested early springs- the paint marks usually remain in addition to BMW part number might be found stamped on a coil. You measure the FREE LENGTH, COIL WIRE DIA. , AND HOW MANY WINDINGS TO IDENTIFY 'STOCK' SPRINGS some info from my past threads - all in the BMW Blue Binder Repair Manuals: ******************************************************** rear coil spring upper rubber 'damper ring' comes in 3 heights: 28 mm height = 1 dot and green color code 33 mm height = 2 dot and white color code 37 mm height = 3 dot and red color code Note: always fit top spring damper with 1 dot for Touring models (of course for orig springs) check availability with dealer, one was NLA reciently. the bottom rear coil spring rubber damper ring comes only in one thickness = 24mm ref. 33-0/8 specifations BMW Repair Manual Vol. 2 and from factory manual: 13.28" = Front std 13.58" = Front Heavy Duty 13.17" Rear std. 14.25" Rear for Baur Convertible ****************************************** subject: 02 springs , color code, free length, lb. rate ... Message: ....here's what I added way back on 01/11/02 on the subject - Message Title: 02 SUSPENSION SPRINGS rates / colors / wire dia. Posted by: Creighton D. on 2002-11-01 at 04:59:47 ( stock 02 susp coil spring colour codes & MORE> this is for oem / stock / BMW factory suspension coil springs ! not aftermarket stock / oem 02 suspension coil spring colour codes and free length (not mounted length); REAR SUSP SPRINGS Green 776-803 lbs White 750-776 lbs Red 725-750 lbs wire thickness 12.3mm (.049")free length unmounted 334.6 (13.17") Heavy duty conversion ( for trailer towing ) grey/green 769-789 lbs grey/white 730-769 lbs grey/red 710-730 lbs wire thickness 13.2mm (.052") free length of unmounted 324.2mm (12.76") FOR touring - USE ONLY RED (in emergency WHITE is permissable always use "1 Dot " rubber top cushion FRONT SUSP SPRINGS green/blue 635-656 lbs white/blue 614-636 lbs red/blue 595-614 lbs wire thickness 11.8mm (0.465") free length unmounted 337.2mm (13.28") Heavy duty conversion (only if rear is also converted) green/grey/green 606/626 lbs white/grey/white 584-606 lbs red/grey/red 564-584 lbs wire thickness 12mm (0.47") free length unmounted 345mm (13.58") ..........SO, AS YOU CAN SEE , WHEN INSPECTING UNKNOWN SPRINGS, THE FREE LENGTH CAN BE CLOSE, BUT IT'S THE WIRE THICKNESS THAT YOU NEED TO MEASURE CAREFULLY THIS REF. FROM BMW REPAIR MANUAL (PRINTED) VOL.2 >>>>>>>>>>>>>>>> HAPPY SPRING HUNTING ! <<<<<<<<<<<<<<" 1 Quote Link to comment Share on other sites More sharing options...
