zippy500 Posted September 9, 2022 Share Posted September 9, 2022 As the title says, Does anyone know if the later Front E21 Shock parts fit the 2002. They seem plentiful and a lot lower priced than the E10's Thanks Quote Link to comment Share on other sites More sharing options...
bergie33 Posted September 9, 2022 Share Posted September 9, 2022 By "Shock top plate", do you mean the front strut mount/bearing assembly? If so, then yes, that part will fit. I don't think anything else will fit, other than the rear trailing arm bushings. Quote Link to comment Share on other sites More sharing options...
TobyB Posted September 9, 2022 Share Posted September 9, 2022 Upper 3- bolt strut mount- yes, as Karl says. Anything below that- no, the front suspension design was changed to make the E21 handle worse than the Ford Twin I- Beam design. t Quote Link to comment Share on other sites More sharing options...
zippy500 Posted September 9, 2022 Author Share Posted September 9, 2022 OK Thanks guys that's helpful as the 2002 top plate is quite expensive. So does the e21 shock insert does not fit the 2002 then ? Any of the front suspension bushing interchangeable with the E21. Looks like it going be a expensive project to refurb the front end then. Quote Link to comment Share on other sites More sharing options...
Mike Self Posted September 9, 2022 Share Posted September 9, 2022 25 minutes ago, zippy500 said: OK Thanks guys that's helpful as the 2002 top plate is quite expensive. When you order that, refer to it as the "upper strut bearing" to insure you get the correct part 26 minutes ago, zippy500 said: So does the e21 shock insert does not fit the 2002 then ? Nope...and be happy--Bilstein HDs have just become available again for 2002s after being NLA for over a year...they're the last ones you'll have to buy. 27 minutes ago, zippy500 said: Any of the front suspension bushing interchangeable with the E21. Nope...but those rubber bushings aren't that expensive...and stick with OEM rubber unless it's a track car...Eurethane bushings (except sway bars) will jar your teeth out on the street. Quote Link to comment Share on other sites More sharing options...
zippy500 Posted September 9, 2022 Author Share Posted September 9, 2022 (edited) 1 hour ago, Mike Self said: Nope...but those rubber bushings aren't that expensive...and stick with OEM rubber unless it's a track car...Eurethane bushings (except sway bars) will jar your teeth out on the street. Yes Thanks, I nearly got talked into poly bushes, have now decided against it, I want the comfort ride, especially as it will be ( purist close your eyes from this point) leaf powered . Edited September 9, 2022 by zippy500 Quote Link to comment Share on other sites More sharing options...
