quequieresvonmir Posted September 9, 2022 Share Posted September 9, 2022 Hello, I,m looking to get a new starter and came across on this one: Product Specification: 1.7 KW/12V, CW, 9-TOOTH PINION Bosch Remanufactured: SR 442X, SR 441X Would this be the one for my 02? Please let me know, thank you Quote Link to comment Share on other sites More sharing options...
danco_ Posted September 9, 2022 Share Posted September 9, 2022 That is a good starter. For future reference, you can use any starter that came on all variations of m10, s14, and m30 engines (manual engines, not sure about automatic). Many later starters are much lighter and stronger than the factory 2002 starters. 1 Quote Link to comment Share on other sites More sharing options...
Solution quequieresvonmir Posted September 9, 2022 Author Solution Share Posted September 9, 2022 Thank you. To add more info about the starter: Gear OD: 1.134 in/28.8mm For BMW 535i, 535is, 635csi, 735i, 735il, M5, M6 Quote Link to comment Share on other sites More sharing options...
1936spyder Posted September 9, 2022 Share Posted September 9, 2022 To echo what Ryan said, I personally would use an S14 starter as they’re not much more expensive (if at all), they’re lighter and they crank faster. Quote Link to comment Share on other sites More sharing options...
Buckeye Posted September 9, 2022 Share Posted September 9, 2022 Me, I don't give up on original starters. IMO, they are better built that aftermarket ones. I just take them apart to see what is wrong with them. In most cases it happens to be worn out carbon brushes that are worn out. Quote Link to comment Share on other sites More sharing options...
John76 Posted September 9, 2022 Share Posted September 9, 2022 If you want the original starter, the Bosch SR71X (remanufactured) from RockAuto is only about $70. Quote Link to comment Share on other sites More sharing options...
