conkitchen Posted September 8, 2022 Share Posted September 8, 2022 (edited) SO; like a good friend with skills, able to perform a headliner install, I agreed to do so. The car gets dropped off. I start in on taking apart the front glass and low and behold. Never seen this type of clip strip used before. They even drilled little holes into the pinch weld for rivets to secure in place. Why they even used it at the bottom edge of the glass up against the dash. What's odd is that the headliner was actually OEM pattern material. It was painted over but look closely and you can see the strip in question. The shit people do. My only guess is the window was replaced in the past by an outfit that used this type of strip to secure the rubber seal. No other reason makes sense. But what do I know Edited September 8, 2022 by conkitchen Quote Link to comment Share on other sites More sharing options...
joysterm Posted September 8, 2022 Share Posted September 8, 2022 (edited) For what its worth, I found the same metal stripes on my car when I started the deconstruct. Mine were held in place by a tiny phillip head screws. I know my windshield had never been touched since leaving the motherland, so it seems another fine example of German over engineering. edit: as an aside the stripe was installed post paint. Edited September 8, 2022 by joysterm Quote Link to comment Share on other sites More sharing options...
conkitchen Posted September 8, 2022 Author Share Posted September 8, 2022 (edited) 6 minutes ago, joysterm said: For what its worth, I found the same metal stripes on my car when I started the deconstruct. Mine were held in place by a tiny phillip head screws. I know my windshield had never been touched since leaving the motherland, so it seems another fine example of German over engineering. Good to know, I may use them to actually hold the headliner in at the top and omit them on the sides and bottom. Come to think, I wonder if this application could solve the corner "seating" issue with the new rubber especially from URO. Hmmmmmmm? Edited September 8, 2022 by conkitchen Quote Link to comment Share on other sites More sharing options...
joysterm Posted September 8, 2022 Share Posted September 8, 2022 (edited) I was under the impression these were designed more to secure the headliner rather than the rubber seal. I’d would urge you to use OEM in any case. Edited September 8, 2022 by joysterm Quote Link to comment Share on other sites More sharing options...
conkitchen Posted September 8, 2022 Author Share Posted September 8, 2022 (edited) 1 hour ago, joysterm said: I was under the impression these were designed more to secure the headliner rather than the rubber seal. I’d would urge you to use OEM in any case. There are/were smaller individual "clips" as seen below used on other cars I have seen. What's on this car is a linier length of metal. Might be hard to see in the picture since they are attached and painted the body color. Edited September 8, 2022 by conkitchen Quote Link to comment Share on other sites More sharing options...
joysterm Posted September 8, 2022 Share Posted September 8, 2022 10 hours ago, conkitchen said: There are/were smaller individual "clips" as seen below used on other cars I have seen. What's on this car is a linier length of metal. Might be hard to see in the picture since they are attached and painted the body color. Have not seen those used for that before....interesting. It looks the car was resprayed with them on place. Mine were bare metal, installed after the car came off the paint line. I know I have the old pieces lying around somewhere, I'll try to dig up. Quote Link to comment Share on other sites More sharing options...
artbo Posted September 8, 2022 Share Posted September 8, 2022 (edited) So, in 72 or so the DOT required windshields stay in place during an accident. These strips were riveted onto the pinch to provide a bit of grip for the gasket. The rubber windshield gasket was also changed to accommodate the added thickness of the strips. If you used an early gasket the strips would show after install. For the most part we just chiseled off the rivets and removed the strips! Never had any negative issues. They have nothing to do with retention of the headliner. Edited September 8, 2022 by artbo Addition 1 Quote Link to comment Share on other sites More sharing options...
HBChris Posted September 8, 2022 Share Posted September 8, 2022 And they are also found on the e9. Quote Link to comment Share on other sites More sharing options...
conkitchen Posted September 9, 2022 Author Share Posted September 9, 2022 6 hours ago, artbo said: They have nothing to do with retention of the headliner. That's kinda what I thought since having it on the bottom edge of the front frame has nothing to do with the headliner. I have removed them. However: I may use a small section in the corners to "puff" out the rubber. To solve that shrinking look that the new rubber seals do once the glass is in. but what do I know. Quote Link to comment Share on other sites More sharing options...
artbo Posted September 9, 2022 Share Posted September 9, 2022 Sounds like a great idea to me? Quote Link to comment Share on other sites More sharing options...
