Dread2002 Posted September 3, 2022 Share Posted September 3, 2022 Hey all! Currently waiting on my subframe to be coated and "while I'm in there" I decided to clean up my oil pan and put a new gasket on. I find myself questioning the painting process, did a quick search on the forum and I couldn't find an answer. Do I need primer on the oil pan? Or can I just hit it with VHT header paint? Also, are their any general rules for painting any of you want to throw out there? Thanks! Quote Link to comment Share on other sites More sharing options...
bergie33 Posted September 3, 2022 Share Posted September 3, 2022 I would use primer as it will adhere better. High temp (header) paint isn't necessary. Regular engine enamel will work just fine. 1 1 Quote Link to comment Share on other sites More sharing options...
esty Posted September 3, 2022 Share Posted September 3, 2022 appliance epoxy, it's tougher against the rocks and other debris...home depot & lowe's sell in in a spray can Quote Link to comment Share on other sites More sharing options...
tech71 Posted September 3, 2022 Share Posted September 3, 2022 (edited) 2 hours ago, Dread2002 said: Also, are their any general rules for painting any of you want to throw out there? Read and follow the instructions on the can? several light, overlapping coats are better than just globbing one heavy wet coat on. Shake, shake, shake and then shake some more. at least thats what the can will say Edited September 3, 2022 by tech71 Quote Link to comment Share on other sites More sharing options...
jgerock Posted September 4, 2022 Share Posted September 4, 2022 “Waiting on my subframe to be coated”… add the oil pan to your list to be powder coated. Of course, only have the outside coated. Quote Link to comment Share on other sites More sharing options...
