sam1904 Posted September 3, 2022 Share Posted September 3, 2022 Hi, struggling with the driver side motor amount as I am struggling to get any meaningful torque on the bolts (red) that hold the bracket to the block (I am also worried that even if I do get them off I will then not be able to get enough torque back on them to be confident in that bracket not moving). Do these definitely need to come off or if I just release the nuts (yellow) on the mount itself has anybody had any luck rocking the motor over enough to allow the threaded rods to escape the brackets? Quote Link to comment Share on other sites More sharing options...
tzei Posted September 3, 2022 Share Posted September 3, 2022 How are you supporting the engine? Bottom yellow circle nut has to come loose. Other needs to be opened fully but just block bolts first to get the part out. Quote Link to comment Share on other sites More sharing options...
sam1904 Posted September 3, 2022 Author Share Posted September 3, 2022 Going to secure / lift under the sump (carefully) with a Jack and wooden block. Just to be sure I understand - are you saying it is, or is not possible to move the motor enough to remove the rubber mount without removing the engine block mounted bracket? It is the bolts securing that bracket to the engine block that I am not able to break in the space I have. Thanks Sam Quote Link to comment Share on other sites More sharing options...
tzei Posted September 3, 2022 Share Posted September 3, 2022 Engine block mounting bracket & rubber mount needs to come out one piece. If you can yank that rubber block out without moving it’s engine side bracket i’d say your rh rubber block is toasted. Quote Link to comment Share on other sites More sharing options...
Son of Marty Posted September 3, 2022 Share Posted September 3, 2022 As you jack the engine up watch the distributor cap to firewall clearance. Quote Link to comment Share on other sites More sharing options...
sam1904 Posted September 4, 2022 Author Share Posted September 4, 2022 Thanks all, Just installed the new drivers (LHS) side and noticed with the washer and deep flanged nylock that was in place there is not a lot of thread engagement on the outside bolt and definitely not any contact with the nylock element. What nut should be used here (parts diagram don't see to give any dimensions). Should there be a washer against the slotted subframe mount element - if so flat or spring? Should it be a plain, flanged or nylock nut? Thanks Sam Quote Link to comment Share on other sites More sharing options...
tzei Posted September 4, 2022 Share Posted September 4, 2022 Flat washer & plain nut Quote Link to comment Share on other sites More sharing options...
sam1904 Posted September 4, 2022 Author Share Posted September 4, 2022 57 minutes ago, tzei said: Flat washer & plain nut Thanks, just saw this after doing plain nut and thin wave washer. Hopefully all good! Sam 1 Quote Link to comment Share on other sites More sharing options...
