Morgan Posted August 19, 2022 Share Posted August 19, 2022 what’s the consensus on staggering wheel sizes on a 2002? I’m thinking about running 175/65/15 on the front and 185/65/15 on the rear. Wheels are 6” mini light style. I’m looking at Continental TRUE CONTACTS Quote Link to comment Share on other sites More sharing options...
TobyB Posted August 19, 2022 Share Posted August 19, 2022 The consensus is that'll give you transitional oversteer. t Quote Link to comment Share on other sites More sharing options...
visionaut Posted August 19, 2022 Share Posted August 19, 2022 It’s not very common on 02s. Most run a square setup. The few staggered I know it’s with wheels not just tires. Why do you want to add understeer to your 02? 1 Quote Link to comment Share on other sites More sharing options...
PhilC Posted August 19, 2022 Share Posted August 19, 2022 I run 6 on the front and 7 on the rear offset 22 on the front 16 on the rear. However, I run the same 185/45/15 tyres all round. Even on my old 911 the rotational circumference was the same even though the widths varied. Quote Link to comment Share on other sites More sharing options...
Tommy Posted August 19, 2022 Share Posted August 19, 2022 4 hours ago, Morgan said: what’s the consensus on staggering wheel sizes on a 2002? I’m thinking about running 175/65/15 on the front and 185/65/15 on the rear. Wheels are 6” mini light style. I’m looking at Continental TRUE CONTACTS Both are way too large in diameter. Why not 195/50/15 square setup? True contact seems to be all-season tire and not available that pretty common size. I'd suggest looking for something else. Quote Link to comment Share on other sites More sharing options...
d.hitchcock Posted August 19, 2022 Share Posted August 19, 2022 Run 195/50-15s all around. Quote Link to comment Share on other sites More sharing options...
Conserv Posted August 19, 2022 Share Posted August 19, 2022 14 hours ago, Morgan said: what’s the consensus on staggering wheel sizes on a 2002? I’m thinking about running 175/65/15 on the front and 185/65/15 on the rear. Wheels are 6” mini light style. I’m looking at Continental TRUE CONTACTS Your car’s original tires, 165/80R13, had an overall outside diameter of 23.2” (perhaps 23.4”, depending on your reference source). A 185/65R15 would have an overall outside diameter of 24.5”. That additional 1.3” (or 1.1”) matters in terms of fitment! If you’re not driving your car in snow — for which you should mount true snow tires (Alpine symbol) — go for summer, not “all-season” tires. Regards, Steve . i" Quote Link to comment Share on other sites More sharing options...
Morgan Posted August 19, 2022 Author Share Posted August 19, 2022 Thanks so much for the info. I am currently running Kumho 195/50/15 on the front and 205/50/15 on the rear. I was hoping to ease some of the steering by going to a smaller tire. And still keep my 6 inch mini lights. Will definitely go for a summer tire. Any advice on 185/55/15 or 185/60/15 all around? 1 Quote Link to comment Share on other sites More sharing options...
Squid's 02 Posted August 20, 2022 Share Posted August 20, 2022 4 hours ago, Morgan said: Thanks so much for the info. I am currently running Kumho 195/50/15 on the front and 205/50/15 on the rear. I was hoping to ease some of the steering by going to a smaller tire. And still keep my 6 inch mini lights. Will definitely go for a summer tire. Any advice on 185/55/15 or 185/60/15 all around? What steering wheel are you running? If you have a smaller Momo steering wheel, then going back to factory will make a big difference in the ease of steering at slower speeds. Quote Link to comment Share on other sites More sharing options...
Gordon Posted August 20, 2022 Share Posted August 20, 2022 8 hours ago, Morgan said: I was hoping to ease some of the steering by going to a smaller tire. What size steering wheel do you have? A small steering wheel makes low speed steering a bitch. Other option is to start weight lifting. ? 1 Quote Link to comment Share on other sites More sharing options...
Conserv Posted August 20, 2022 Share Posted August 20, 2022 6 hours ago, Gordon said: What size steering wheel do you have? A small steering wheel makes low speed steering a bitch. Other option is to start weight lifting. ? And to manage expectations, even with the original 165/80HR13 XAS’s and the factory steering wheel, parallel parking an ‘02 can be a bitch, if somewhat less of a bitch than with fat tires and a small wheel… ? I have a restored 1961 Ford F-350 pickup. Manual steering. 19.5” rims. Enormous Michelins. Much easier to turn at driveway speeds than an ‘02 with stock rims and tires. What’s up with that? ? Regards, Steve Quote Link to comment Share on other sites More sharing options...
TobyB Posted August 21, 2022 Share Posted August 21, 2022 14 turns lock- to lock, I'd imagine! heh t more likely the Ford has a much lower scrub radius. The struts on a 2002 swing the tires in a rather large arc... 1 Quote Link to comment Share on other sites More sharing options...
Conserv Posted August 21, 2022 Share Posted August 21, 2022 2 hours ago, TobyB said: 14 turns lock- to lock, I'd imagine! heh t more likely the Ford has a much lower scrub radius. The struts on a 2002 swing the tires in a rather large arc... Not a lot of turns, Toby, So I’m going with your “lower scrub radius” theory. How low is it? That truck’s scrub radius is so low it’s a negative number… ? That’s my new story and I’m stickin’ to it! Thanks and best regards, Steve Quote Link to comment Share on other sites More sharing options...
ray_ Posted August 21, 2022 Share Posted August 21, 2022 2 hours ago, Conserv said: Not a lot of turns, Toby, So I’m going with your “lower scrub radius” theory. How low is it? That truck’s scrub radius is so low it’s a negative number… ? That’s my new story and I’m stickin’ to it! Thanks and best regards, Steve Because you're a manly man when you drive that! 1 Quote Link to comment Share on other sites More sharing options...
Morgan Posted August 26, 2022 Author Share Posted August 26, 2022 Thanks for the input. Unless I can find chromadora or campagnola wheels I will probably stay with my mini lights and the 195/50/15 front and 205/50 rear set up. Quote Link to comment Share on other sites More sharing options...
