How To Fit a Modern Fuel Sender Unit To The 02 Gas Tank?
Go to solution Solved by TobyB,
20 hours ago, calw said:
Worth at least a dime, Jim.  Some capacitance across the circuit at the gauge input might kinda sorta simulate the de-sloshing effect of the surround, but there must be a good reason for the physical method, and circuit analysis or cut-and-try electrical engineering would be needed to determine how much C to install.
Oh look, there's a.... :)
airvariablecap_dual120pf1b__93421.162109
KE9PQ.COM
Air Variable Capacitor Dual 15 to 120 pF each, in Excellent Condition
Ray
Thanks for the helpful information and suggestions.
I was not aware of the Speedhut and Autometer 0-90 ohms gauges. Using one of those would be the easiest solution. Speedhut is very expensive, Autometer more reasonable. But, in the end, I think I'd just like to move away from relying on a 48-year-old sending unit.
Brazing the old flange to a new unit is a simple and fairly easy solution - I slapped my forehead and said "brilliant"!  But then I thought, I struggle just with solder and it's been twenty years since I last made a mess with an oxy/act torch, maybe that's not the best way for me.
I was not familiar with Rivnuts. Although I'll need to drain and pull the tank, I think this may be the best solution for me. If I put in a 240-33 ohms unit, I'll have a much wider variety of gauge faces to choose from.
Greg S. -
KE9PQ.COM
A trunk-full of those might approach the needed capacitance.  And, it's fine-tuneable....  No, NOT the sort of capacitor that I meant, way too little capacitance.
Yer' maybe lookin for a time constant in the most-of-a-second range to damp the bouncing gas gauge needle, one of those aif variables will get you to the microsecond range or so.  Hafta measure the internal resistance of the gas gauge meter movement and factor that in with the sender's resistance and a wild guess about how much debouncing is needed, then keep trying until you get it right.
