ghost in the clutch!!
With the manual transmission not in gear and the parking brake off, I started my car to check the oil pressure light after changing the oil. The car began slowly rolling forward and started to pick up speed. The handbrake was enough to stop it.
Anyone else ever experience this? What causes it? What should I check. The master and slave clutch cylinder were both replaced last fall (not by me). Thanks for any insight.
bat
Throw out bearing was/is slightly long (I think?) after I fabbed one up (thank you, Jeff I.) using turned aluminum collar that I calculated incorrectly (D'oh!) the shoulder the new
bearing would sit against.
Of course slow rolling could also be caused by subtle interaction between your car, a sloped grade and, gravity.
