Looking at Rebuilt 2002 Head
I
I'd confirm the thickness of the head, and if seller is trust worthy, I
would buy it before someone else does. I have recently sold used 318 heads like this for 200-250 dollars.
This is already taken apart, so you could take it to a machine shop, have them double check and put in a cam that fits a 2002. I'm assuming it has a cam with teeth that don't match an 02 distributor.
I wouldn’t touch that . $485 for what? That guy is either  shady, ignorant or both.
Why the interest in a 1:8 head? On a 2L engine they only work with flat top pistons  and tha cam gear is cut backwards.
Guys feed back has at least 3 negative reviews for “scrap “ cylinder heads
Edited by tech71
  • Like 3
1 hour ago, Labphoto said:
What’s involved in fitting a 2L head? Is it a direct fit?
What engine are we talking about here? 2L or 1.8L?
From a 2002 0r an E21 320i?
More to the point, what do your piston tops look like?
Edited by tech71
Did you not notice the big gouge out of it? And whats going on with the front intake surface? I'd be very hesitant to buy a used head without the opportuniy to have it checked, unless from reputable seller. As above, thickness needs to be within specs.
Edited by Hans
24 minutes ago, Labphoto said:
I was having a hard time determining if it was a 1.8L or 2.0L, thank you for clarifying
By definition, a 2002 is 2 liters, an 1802 is 1.8 liters, and a 1602 is 1.6 liters. Notice a pattern developing? OK, a 1502 is also 1.6 liters, but with a lower compression ratio than a 1602… 😯🤫😉
