hood latch part number
DrA76
That part is NLA, but RealOEM lists the number in this diagram.
1502-2002tii 2002 Engine hood/mounting parts
Sponsored links
No. Description Supp. Qty  From   Up To  Part Number Price   Notes
01 Circlip 6,0 2   07/1977 07119932842 $0.09   ENDED
01 Circlip 6,0-ZNS3 2     07119905695 $1.07
02 Shim 1,500MM 2     23311230689 $0.36   ENDED
03 Roll pin   2     51235480138 $3.05
04 Bow   2     51235480134     ENDED
05 Clamping bush 4 X 16 2     07119941365     ENDED
06 Cable roller   1     51231813490     ENDED
07 Retainer spring   1     41615480169 $8.15   ENDED
07 Retainer spring   1     51231801010     ENDED
08 Hood lock   1     51235480136     ENDED
09 Bowden cable   1     51235480164 $15.13
10 Grommet   1     51715480172     ENDED
11 NIpple   1     07119988505 $1.73
  fitted alternatively
12 Hex head screw with washer A6,5X19 2     51231806882 $0.77
12 Hex bolt M6X25 2     52101820255 $0.35   ENDED
13 Lever   1     51231801019     ENDED
14 Button   1     41335680162 $14.81
15 Cup   1     41615480167     ENDED
16 Gasket   1     51235480192 $33.70
17 Stopper   1     41615480193 $7.53   ENDED
18 sealing   1     51235480191 $40.02
19 Csk.fillister head srew M6X35 4     07119928533 $1.79
20 Sealing front   1     41615480195 $41.17
20 SEALING FRONT right   1     41615480196 $41.17
21 Guide   2     41615480156 $12.76   ENDED
22 Guide   2     41615480155 $12.76   ENDED
23 Support   2     41615480170 $11.59
24 Set fillister head screw 20 M6X16 4     07509063320     ENDED
24 Fillister head screw M6X16 4     07119906423 $0.18
25 Stop buffer
